Author Topic: BricsCAD Dimension Text Direction  (Read 2720 times)
Keith Brown
« on: September 21, 2016, 09:46:57 AM »
In AutoCAD I can set the dimension text direction of a RotatedDimension using the property Dimtxtdirection, but in Bricscad this property does not exist on a rotated dimension.  I went to
https://www.bricsys.com/bricscad/help/en_US/V12/UsrGui/source/10_Drawing_Entities/06_Working_with_Dimensions/10_06_02_Dimension_Settings.htm
and could not find anything that would help.  Any ideas?  Thank you.
Re: BricsCAD Dimension Text Direction
« Reply #1 on: September 21, 2016, 05:29:44 PM »
Have a look at TextRotation and TextPosition properties, the direction is a vector from the position with a rotation
- John Carmack
- J.R.R. Tolkien
Keith Brown
« Reply #2 on: September 22, 2016, 08:45:31 AM »
Thanks Mick,  I will look into that.  I was hoping it was as easy as just having a flag to reverse it.
« Reply #3 on: September 22, 2016, 05:50:02 PM »
Ah, you mean to reverse the text, not rotation. Sorry about that.
I think the best you can do is maybe flip the Normal vector of the dimension which should draw it reversed.
btw, I couldn't find the Dimtxtdirection property while searching the AutoCAD help doc's, is this a property in the editor properties dialog?
- John Carmack
- J.R.R. Tolkien
Keith Brown
« Reply #4 on: September 23, 2016, 08:52:20 AM »
Yes, it is a property on the property palette.   I'll try the normal.  I was not messing with any of the dimension properties other than the text direction.  Everything else was at its default and i was just transforming the entire dimension.  I found it easier than calculating all the vectors especially when working with viewports as the view can be from any direction and the dimension must always read left to right and down to up if vertical.
