Author Topic: (C3D 2016) Viewframes  (Read 4213 times)
« on: September 21, 2016, 09:19:29 AM »
Is there a way to renumber view frames? I have a drawing with 38 of them and i would like to renumber them to match the sheets they are associated with.
thanks
Re: (C3D 2016) Viewframes
« Reply #1 on: September 21, 2016, 10:54:58 AM »
Rename, yes. Renumber, no.
« Reply #2 on: September 22, 2016, 09:11:35 AM »
one could just recreate the view frames....and set the naming/number to match what is desired.
« Reply #3 on: September 22, 2016, 10:57:59 AM »
But how would that affect my sheets?
« Reply #4 on: September 22, 2016, 02:04:14 PM »
unless one regenerate the sheets, NOTHING would happen to your existing sheets
« Reply #5 on: September 22, 2016, 06:08:44 PM »
Except you'd lose matchline stationings, links to sheets, etc.  Ya know, I'm not seeing that you can specify the numbering of the VF's anyway. Yes, it has a counter for the Name, but they always get numbered with the lowest available (usually 1), as far as I can tell.
BlackBox
« Reply #6 on: September 23, 2016, 01:00:26 PM »
I've never been able to use View Frames... Requires an Alignment (no grid setup for subdivisions?), so I end up just using Fields with SSM sheet numbers for match lines. *shrugs*
« Reply #7 on: September 26, 2016, 09:47:38 AM »
One can use view frames for subdivisions..invisible alignments 'squared' to your desired sheet order
and you do not need profile frames, just plan frames it's not that hard to do.
