Author Topic: Checking for Perpendicular  (Read 1963 times)
nobody
  • .net stuff
« on: September 20, 2016, 09:54:57 PM »
Maybe I'm just tired but shouldn't this return true if my two points are perpendicular to the polyline?
Code - C#: [Select]
  1.      private static bool ninetycheck(Point3d pt1, Curve curve)
  2.         {
  3.             Editor MyEditor = Application.DocumentManager.MdiActiveDocument.Editor;
  4.
  5.             Matrix3d mat = MyEditor.CurrentUserCoordinateSystem;
  6.             Point3d basept = pt1.TransformBy(mat);
  7.             Point3d pt = curve.GetClosestPointTo(basept, false);
  8.             Vector3d v3d = basept.GetVectorTo(pt);
  9.             Vector3d derv3d = curve.GetFirstDerivative(pt);
  10.             if (v3d.IsPerpendicularTo(derv3d))
  11.             {
  12.                 return true;
  13.             }
  14.
« Last Edit: September 20, 2016, 10:08:57 PM by Area51Visitor »
MickD
Re: Checking for Perpendicular
« Reply #1 on: September 20, 2016, 11:47:35 PM »
Just flying past with a quick thought...
Have you tried normalising the vectors first?
- John Carmack
- J.R.R. Tolkien
nobody
  • .net stuff
« Reply #2 on: September 21, 2016, 10:00:46 AM »
Thanks Mick...will give that a shot
Bryco
« Reply #3 on: September 22, 2016, 08:20:55 PM »
And add a tolerance
