Code Red > VB(A)
Selectionset Woes
(1/1)
Swift:
Greetings All,
Been a long time. I apologize before hand for not posting a snippet, but I riding shotgun down the interstate, trying to write some vba. So I'm posting from my phone.
What I'm trying to do is set a selectionset by window or fence, process the selection set then reset the selection set window for different items.
The problem is that after the initial selection I can never select anything else. I've tried clearing the selectionset, deleting it, set it to nothing and reseting in my outside loop but I can't get it to ever select anything on the second iteration of the loop.
I'm wondering if I've hit a hidden vba feature?
Thoughts?
jouni:
Try this method:
On Error Resume Next
Set selSet = myDoc.SelectionSets.Add("Objects")
If Err.Number <> 0 Then
myDoc.SelectionSets.Item("Objects").Delete
Set selSet = myDoc.SelectionSets.Item("Objects")
selSet.Clear
End If
selSet.Clear
selSet.SelectOnScreen
selSet.Highlight True
selSet.Highlight False
selSet.Clear
selSet.Delete
Navigation
[0] Message Index
Go to full version
