Author Topic: Imperial String to Imperial distance  (Read 2458 times)
SPDCad
« on: May 16, 2005, 02:25:59 PM »
Does anyone have a lisp that will convert an imperial distance in the form of a string to the actual imperial distance.
example
input:  "18'2\" "
output:  18'-2"
I am requesting user input in a dialog box and the value is returned as a string not a number.
Any help would be greatly appreciated.
AutoCAD 2010, w/ OpenDCL
visit: http://reachme.at/spd_designs
whdjr
« Reply #1 on: May 16, 2005, 02:57:54 PM »
This is probably your best bet:
Converts a string into a real number
(atof string)
Arguments
string
A string to be converted into a real number.
Return Values
A real number.
Examples
Command: (atof "97.1")
97.1
Command: (atof "3")
3.0
Command: (atof "3.9")
3.9
« Reply #2 on: May 16, 2005, 03:04:13 PM »
I'm not sure I understand, but given --
(defun distanceof ( x  / result )
    (vl-catch-all-apply
       '(lambda ()
            (vl-some
               '(lambda (units) (setq result (distof x units)))
                (list (getvar "lunits") 4 5 2 1)
    result
Perhaps --
(rtos (distanceof "18'2\"") 4 2)
=> "18'-2\""
SPDCad
« Reply #3 on: May 16, 2005, 03:15:15 PM »
Quote from: MP
(rtos (distanceof "18'2\"") 4 2)=> "18'-2\""
Thats its, I forgot about the DISTOF command!
Thanks MP.
:O)
