Author Topic: Strange "thing" in layout tab. What is it?  (Read 6412 times)
alanjt
  • Standby for witty remark...
« on: September 09, 2016, 10:46:38 AM »
It happens once in a while and it doesn't screw up the drawing. It's just odd, and annoying.
Does anyone know what this is, or how to get rid of it?
If I zoom in/out, it stays in the same place.
I'm 99% sure I've only seen it in paperspace layouts, but I could be wrong.
Dropbox
Re: Strange "thing" in layout tab. What is it?
« Reply #1 on: September 09, 2016, 10:49:46 AM »
I've seen this for years and have never figured out what it is, why it's there, or what triggers it to show up. It doesn't plot so I just ignore it now.
Rob...
« Reply #2 on: September 09, 2016, 10:50:03 AM »
I've seen that before. I think it is text. Since you are asking, I'm assuming you cannot select it. Try Ctrl+A and then deselect everything else. That should leave the offending entity selected so you can find out what it is and delete it.
CAD Tech
alanjt
« Reply #3 on: September 09, 2016, 11:02:44 AM »
It's not text, and there's no way to select it.
If you zoom way out and regen, it will display in a different spot.
Graphically, it looks like something outside of cad.
I've always ignored it. I guess I just thought I'd finally take a moment to ask.
Dropbox
Rob...
« Reply #4 on: September 09, 2016, 11:05:46 AM »
How do you know if you can't select it?
I'm pretty sure I've been able to select it. I am sure I've been able to get rid of it.
Can you post a file that has it?
CAD Tech
Matt__W
  • I like my water diluted.
« Reply #5 on: September 09, 2016, 11:10:36 AM »
Try QSELECT??
Autodesk Expert Elite
danallen
« Reply #6 on: September 09, 2016, 11:53:05 AM »
erase > all, if still there, list > all ?
« Reply #7 on: September 09, 2016, 12:08:53 PM »
yeah, post a drawing with it present.  I've not encountered it, whatever it is.
Matt__W
« Reply #8 on: September 09, 2016, 01:29:03 PM »
You mean "Pennywise"?
alanjt
« Reply #9 on: September 09, 2016, 05:00:49 PM »
Well, I was going to post it, but cad crashed, and when I reopened the drawing, pennywise was gone.
Dropbox
Rob...
« Reply #10 on: September 09, 2016, 05:28:11 PM »
It's still there unless you run some sort of purge during your startup. It should come and go at different zoom levels.
CAD Tech
alanjt
« Reply #11 on: September 11, 2016, 10:12:37 AM »
The purge command runs once at startup, but I purged/audited the drawing multiple times and it never went away.
Dropbox
Jeff H
« Reply #12 on: September 11, 2016, 08:27:57 PM »
anyone have a example drawing containing it.
Matt__W
« Reply #13 on: September 12, 2016, 10:10:07 AM »
Yeah, not sure what you'll find though.
tedg
« Reply #14 on: September 12, 2016, 12:09:07 PM »
I have this thing at the corner of my drawing, very annoying.
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
