I appreciate the help of Lee and others, and it is my fault for not mentioning this before but I am not able to run this on AutoCAD for Mac. Running a google search I realize this is something not fully supported in the Mac version.
I also use a PC sometimes, but dont have access to it right now to test.
EDIT: I found this code online which worked, after manually selecting every block but it worked alright. I wish I could try your solutions, though.
;; Formerly TIP 1011: ME.LSP (C)1994, Gary Goode
;; (I've changed the name to DD.LSP and changed the defun to DD, B.K.)
;This program will let you pick and edit multi text and attributes
;by window, pick or crossing using dialog boxes.
(defun C:DD (/ A B C D E F G H J K L M )
(graphscr)
(setvar "BLIPMODE" 0)
(setvar "CMDECHO" 0)
(setvar "HIGHLIGHT" 1)
(prompt "\nMulti-Edit is loaded ... ")
(setq A (ssget) B (sslength A) C 0)
(while (< C B) (setq D (ssname A C) E (entget D))
(setq F (car E))
(setq G (cdr E))
(setq H (car G))
(setq J (cdr H))
(setq K "TEXT")
(setq L "INSERT")
(setq M "DIMENSION")
(if (= J K)(command ".ddedit" D ""))
(if (= J L)(command ".ddatte" D ))
(if (= J M)(prompt "\n You picked a dimension, I only do text or attributes ..."))(terpri)
(setq C (1+ C)))
); end me.lsp
