Author Topic: Scale of Drawing  (Read 1370 times)
nobody
  • .net stuff
Scale of Drawing
« on: September 01, 2016, 12:58:21 AM »
Without using "dimscale", is there another "Field" property that will let me get the scale of a drawing / view without selecting an object?
Daniel J. Ellis
Re: Scale of Drawing
« Reply #1 on: September 01, 2016, 03:43:32 AM »
Each viewport has its own scale.
If you need a manual while-you're-CADing check just select the viewport and it will be listed on the properties box.  If you need a LISP method then try googling AutoCAD LISP viewport DXF code or something similar...
dJE
dJE
