Author Topic: Make a ComboBox display images or icons with text in vb.net  (Read 6612 times)
samideqlqpart
« on: August 31, 2016, 04:41:21 PM »
 hello everybody
my problem is how to make a ComboBox that displays either a series of color samples or a list of images
or how to make a ComboBox that displays a series of images with associated text.
i've made one but
icons in my combobox are not like i want
here is my code and result
Private Sub ComboBox1_DrawItem(ByVal sender As System.Object, ByVal e As System.Windows.Forms.DrawItemEventArgs) Handles ComboBox1.DrawItem
        If (e.Index <> -1) Then
            e.Graphics.DrawImage(ImageList1.Images(e.Index), e.Bounds.Left, e.Bounds.Top)
            e.Graphics.DrawString(Me.ComboBox1.Items(e.Index).ToString(), e.Font, System.Drawing.Brushes.Black, e.Bounds.Left + ImageList1.Images(e.Index).Width, e.Bounds.Top)
        End If
    End Sub
thank you
BillZndl
Re: Make a ComboBox display images or icons with text in vb.net
« Reply #1 on: September 01, 2016, 06:30:37 AM »
I would think an imageList control should handle this.
Or, just use listview:
Code - C#: [Select]
  1. listView1.View = View.Details; // Enables Details view so you can see columns
  2. listView1.Items.Add(new ListViewItem { ImageIndex = 0, Text = "Image 1" });
  3.
Source:
http://stackoverflow.com/questions/17151776/c-sharp-listview-adding-item-with-image-and-text-and-align-the-text-to-left
« Last Edit: September 01, 2016, 06:50:04 AM by BillZndl »
MexicanCustard
« Reply #2 on: September 01, 2016, 07:14:11 AM »
WPF. Just saying.
MickD
- John Carmack
- J.R.R. Tolkien
Keith Brown
« Reply #4 on: September 01, 2016, 07:38:57 AM »
Syncfusion has a free set of controls for individuals and small businesses.   I do not use the controls personally but they do have a combobox that looks like it might work for what you want.
https://www.syncfusion.com/products/communitylicense
MickD
« Reply #5 on: September 01, 2016, 06:42:29 PM »
So it seems as though you now have some options, as MexicanCustard suggested, WPF is your best solution even if learning how is a bit harder than WinForms, you get a lot more control of the appearance of your forms.
Whatever you choose, give it a go and if you get stuck I'm sure we can give you more specific help once you have some code to review.
cheers.
- John Carmack
- J.R.R. Tolkien
samideqlqpart
« Reply #6 on: September 02, 2016, 04:12:30 PM »
thank you
i found this
very helpful
http://www.devasp.net/net/articles/display/365.html
BillZndl
« Reply #7 on: September 06, 2016, 03:32:29 PM »
I couldn't get imagelist to work correctly either except on small 16x16 icons.
MexicanCustard
« Reply #8 on: September 06, 2016, 04:27:56 PM »
Just to show how simple this would be using WPF.
<Window>
    <Window.Resources>
        <DataTemplate DataType="{x:Type MyClass}">
            < StackPanel Orientation="Horizontal">
                <Image Source="{Binding Image}" Width="20" Height="20"/>
                <TextBlock Text="{Binding Text}"/>
            </StackPanel>
        </DataTemplate>
    </Window.Resources>
    <Grid>
        <ListBox ItemsSource="{Binding MyList}"/>
    </Grid>
</Window>
