Hi All
I am stumped again. I have a network of polylines. Many have common start and/or end points. I want to insert a block at each start/end but only if there is not already one there. I use ssget to collect all the entities at a point and process for a valid block. If not found, I insert one. The problem is that when I get to the start/end point of another polyline that coincides with the location of the block recently inserted, the ssget does not collect the previous block in the selection set. It is like that block doesn't exist until the program finishes, but I can see them being inserted. I have increased (setq ssa (ssget "C" pt pt)) to (setq ssa (ssget "C" (mapcar '- pt '(0.05 0.05 0)) (mapcar '+ pt '(0.05 0.05 0)))) to see if I can capture more...but to no avail. Any ideas?
