Author Topic: Blocks inserted by Lisp not found by next ssget  (Read 2944 times)
Prickle Farmer
  • 35+ years of AutoCAD / BricsCAD
« on: August 31, 2016, 01:10:32 AM »
Hi All
 I am stumped again.  I have a network of polylines. Many have common start and/or end points.  I want to insert a block at each start/end but only if there is not already one there. I use ssget to collect all the entities at a point and process for a valid block. If not found, I insert one.  The problem is that when I get to the start/end point of another polyline that coincides with the location of the block recently inserted, the ssget does not collect the previous block in the selection set.  It is like that block doesn't exist until the program finishes, but I can see them being inserted.  I have increased (setq ssa (ssget "C" pt pt)) to (setq ssa (ssget "C" (mapcar '- pt '(0.05 0.05 0)) (mapcar '+ pt '(0.05 0.05 0)))) to see if I can capture more...but to no avail.  Any ideas?
I'd rather have a bottle in front of me than a frontal lobotomy.
kpblc
Re: Blocks inserted by Lisp not found by next ssget
« Reply #1 on: August 31, 2016, 01:14:12 AM »
To use (ssget "_C" ...) or (ssget "_W" ...) you have to show all bounds at screen.
I think the better way is to use selection set of all blocks and check - does some block inserted at specified point.
Sorry for my English.
« Reply #2 on: August 31, 2016, 01:16:18 AM »
Consider pre processing the candidate end points first, ensuring there are no duplicates, then insert the blocks, one per unique endpoint.
Prickle Farmer
« Reply #3 on: August 31, 2016, 01:47:53 AM »
Thanks kpblc.  The problem is that the blocks do not exist before the program is rum
Thanks MP.  You are suggesting building a list of points, checking that each new point is not already a member, then inserting the blocks at each point in the list.  Hmm, good work around. I think that will work.  Thanks.
« Reply #4 on: August 31, 2016, 09:07:51 AM »
Not a 'work around' but a logical solution.  8)
I assume you are using a version of the 'traveling salesman' algorithm?
http://goo.gl/LmOZSv
alanjt
  • Standby for witty remark...
« Reply #5 on: August 31, 2016, 09:24:15 AM »
As you step through the polyline selection set, check if each start/end point is a member of an existing point list. If not, add to list and insert block.
Dropbox
« Reply #6 on: August 31, 2016, 10:57:43 AM »
Simplified examples to serve as food for thought --
Pre-processing a list of points to ensure each is unique on the basis of the fuzz value:
(defun _UniquePoints ( points fuzz / result )
    (foreach p points
            (null
                (vl-some
                    (function (lambda (p!) (equal p p! fuzz)))
                    points
            (setq result (cons p result))
    (reverse result)
That established ...
(foreach p (_UniquePoints candidate_points 0.001))
    (_MakeBlockInstance p)
Alternatively, processing points on the fly (assuming vars in code below have been initialized) ...
(foreach p candidate_points
        (null
            (vl-some
                (function (lambda (p!) (equal p p! 0.001)))
                processed_points
            (setq processed_points (cons p processed_points))
Other means can be used to determine uniqueness, e.g. the distance function substituting a maxdist value for fuzz etc.
Anyway ... hope it helps some way ... coded fast hoping no errors ... cheers.
PS: Mods: Pls don't change the code tags, thanks.
« Reply #7 on: August 31, 2016, 02:44:37 PM »
Another spin on _UniquePoints just for fun:
(defun _UniquePoints ( points fuzz / p result )
    (while points
        (setq
            result (cons (setq p (car points)) result)
            points (vl-remove-if (function (lambda (p!) (equal p p! fuzz))) (cdr points))
    (reverse result)
May be faster (guess) on large lists with lots of duplicates but hasn't been benched or tested. Cheers.
Prickle Farmer
« Reply #8 on: August 31, 2016, 06:21:05 PM »
I thought there was still $1million for creating the "traveling salesman".
Thanks MP.  The fuzz factor was just what I was thinking about.  I checked my test drawing and found a misclose of 0.00000002 at one junction.  I know this should not occur but I don't have "complete and supreme control" over my CAD operators.  Such is life.  Your code looks good.  Thanks.  I am still confused as to why ssget can't see objects inserted by my code.  I must tell myself to get a life and move on!!
« Reply #9 on: August 31, 2016, 06:28:10 PM »
Since the result of the graphical ssget selection methods (i.e. C/F/W/CP/WP etc.) is determined by the objects visible in the drawing area at the time of evaluation, ssget will not obtain a selection of newly generated objects until the drawing area is redrawn, which will depend on the method you are using to insert your blocks.
danallen
« Reply #10 on: August 31, 2016, 08:21:23 PM »
on the subject of ssget & C filter, is there a way to combine with lock filter? I have success with
  1. (ssget "C" pt1 pt2)
  2. ;;or
  3. (ssget ":L")
 but not
  1. (ssget "C:L" pt1 pt2)
the alternative is to create a list of locked layers and use a (-4 . "<NOT") filter by those layers, just wondered if I was missing something
Thanks - Dan
Prickle Farmer
« Reply #11 on: September 01, 2016, 03:14:23 AM »
Thanks Lee.  To me, that means that any lisp action can only apply to objects in the "display list" at the time of execution.  I even tried peppering my code with a "regen" or two but that didn't work either.    My problem has been solved by MP's suggestion.  Thanks MP.  I found similar code on your site too, Lee.   Cheers  Phil.
« Reply #12 on: September 01, 2016, 01:03:10 PM »
  2. ;;or
  3. (ssget ":L")
 but not
As far as I am aware, the :L mode string can only be used in conjunction with user selection mode strings (as opposed to automatic selection mode strings).
No, this restriction only applies to graphical ssget selection methods (such as C/F/W/CP/WP etc.).
« Reply #13 on: September 01, 2016, 05:33:58 PM »
Glad you've a fix going forward PF. Thanks for chiming in with useful info (as usual) LM. Cheers all.
« Reply #14 on: September 01, 2016, 06:21:37 PM »
Cheers MP, a delight to see you posting again.
