Author Topic: Understanding DWGs alittle better. . .  (Read 2544 times)
MSTG007
« on: August 26, 2016, 12:59:06 PM »
I hope this make me see like I am smart asking this, but I totally can see it making me look ________ on the other side of it...
Lets say I have a Detail Sheet. That has detail blocks in it with an xref Title Block. The file size is 2MB. Details are in model space and title block is in paper space.
I detach the title block xref and save the Detail Sheet. The file size is still 2MB.
I then, WBLOCK out the details in modelspace to a new drawing. The file size is about 250KB. (cool.)
I then xref the same title block into the wblock dwg. Save the file and the file size is 2MB.
I go one step further, I wblock out the title block which has a size of 70KB. I xref that into the wblock details and save the file. The file size is 2MB.
Am I missing something here? I did this test on my workstation, detached from the network and reconfigured CAD by removing my app data stuff. (So very similar to a new install).
Thanks for any feedback... Just trying to understand.
Also, anyone using Civil3D2016 have their purge dialog box appear very very slowly / delayed?
Civil3D 2020
Re: Understanding DWGs alittle better. . .
« Reply #1 on: August 26, 2016, 01:09:33 PM »
Might be tons of registered applications in the titleblock.
MSTG007
« Reply #2 on: August 26, 2016, 01:13:38 PM »
Yup, Even in the WB Titleblock dwg, I did run an audit pu and a -pu on it.
Civil3D 2020
« Reply #3 on: August 26, 2016, 01:44:09 PM »
Whenever I question the size of a drawing, I run the code from below
https://www.theswamp.org/index.php?topic=9433.0
« Reply #4 on: August 26, 2016, 02:11:31 PM »
you sure seem to be having a lot of these, "Why are my files so freakin uuuuuge?" questions lately.
MSTG007
« Reply #5 on: August 26, 2016, 02:13:17 PM »
Yup, I think we applied a patch a few weeks ago for our feature lines issue. and trinkeling down to now, its taking forever to open these files... its just weird.
Civil3D 2020
« Reply #6 on: August 26, 2016, 02:14:48 PM »
so it would appear the network file fix really wasn't the fix you thought it was
MSTG007
« Reply #7 on: August 26, 2016, 02:18:34 PM »
yup... its our Civil3D2016. I am getting the same results on a LAB workstation as I am getting on my workstation.... I know the 360 service had issues. did that ever get back up and running smoothly?
Civil3D 2020
« Reply #8 on: August 26, 2016, 02:22:21 PM »
Inspect the drawing with MP's code.
