(defun c:test (/ AT:MakeReadable ss i d)
(defun AT:MakeReadable (ang)
;; Make angle readable
;; Alan J. Thompson, 12.14.10 / 11.02.11
(cond ((> ang (* pi 2.)) (AT:MakeReadable (- ang pi)))
((minusp ang) (AT:MakeReadable (+ ang pi)))
((if (and (> ang (/ pi 2.)) (<= ang (* pi 1.5)))
(+ ang pi)
ang
(if (setq ss (ssget "_:L" '((0 . "DIMENSION"))))
(setq o (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
(if (eq (vla-get-objectname o) "AcDb2LineAngularDimension")
(vla-put-textrotation
o
(AT:MakeReadable
(angle
(vlax-get o 'textposition)
(apply
'inters
(reverse
(cons
nil
(mapcar
(function (lambda (prop) (vlax-get o prop)))
'(ExtLine1EndPoint ExtLine1StartPoint ExtLine2EndPoint ExtLine2StartPoint)
