Author Topic: Configure Angular Dim  (Read 1825 times)
« on: August 25, 2016, 11:06:32 AM »
Is it possible to configure a angular dimension so that the text is radial?
alanjt
  • Standby for witty remark...
Re: Configure Angular Dim
« Reply #1 on: August 25, 2016, 12:08:54 PM »
(defun c:test (/ AT:MakeReadable ss i d)
  (defun AT:MakeReadable (ang)
    ;; Make angle readable
    ;; Alan J. Thompson, 12.14.10 / 11.02.11
    (cond ((> ang (* pi 2.)) (AT:MakeReadable (- ang pi)))
          ((minusp ang) (AT:MakeReadable (+ ang pi)))
          ((if (and (> ang (/ pi 2.)) (<= ang (* pi 1.5)))
             (+ ang pi)
             ang
  (if (setq ss (ssget "_:L" '((0 . "DIMENSION"))))
    (repeat (setq i (sslength ss))
      (setq o (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
      (if (eq (vla-get-objectname o) "AcDb2LineAngularDimension")
        (vla-put-textrotation
          o
          (AT:MakeReadable
            (angle
              (vlax-get o 'textposition)
              (apply
                'inters
                (reverse
                  (cons
                    nil
                    (mapcar
                      (function (lambda (prop) (vlax-get o prop)))
                      '(ExtLine1EndPoint ExtLine1StartPoint ExtLine2EndPoint ExtLine2StartPoint)
Dropbox
« Reply #2 on: August 25, 2016, 02:36:37 PM »
That works great. :)
alanjt
« Reply #3 on: August 29, 2016, 11:41:16 AM »
Dropbox
