Author Topic: How to change attribute text height  (Read 3286 times)
GDF
« on: August 25, 2016, 07:57:50 AM »
The code below with change the attribute text width, how can it be modified to change the text height?
(defun c:test (/ sset cnt enam attlst att)
  (setvar "cmdecho" 0)
   ;(ARCH:SET-ARIAL)
  (setq SSET
         (ssget
           "X"
           (list
             (cons 0 "INSERT")
             (cons
               2
               "*PN*"
             (cons 8 "*A-,P-*,M-*,S-*")
        CNT 0
  (if SSET
      (repeat (sslength SSET)
        (setq ENAM (ssname SSET CNT)
              CNT  (1+ CNT)
        (if (= (cdr (assoc 66 (entget ENAM))) 1)
            (setq ATTLST (vlax-safearray->list
                           (variant-value
                             (vla-getattributes
                               (vlax-ename->vla-object ENAM)
            (foreach
                   ATT
                      ATTLST
                (or (wcmatch (strcase (vla-get-stylename ATT)) "ARIAL")
                   (ARCH:WORKING)
                   (vla-put-stylename ATT "ARIAL")
                   (vla-put-scalefactor ATT 1.0) ;;text width
      (prompt
        "\n*      Attribute: Textstyle Notes completed      *"
[\code]
ChrisCarlson
Re: How to change attribute text height
« Reply #1 on: August 25, 2016, 08:11:02 AM »
It's still early in the Am but attribs should follow text properties
GDF
« Reply #2 on: August 25, 2016, 08:32:03 AM »
I already tried that...and got an activex error.
I found this by LeeMac
http://www.lee-mac.com/attmodsuite.html
« Reply #3 on: August 25, 2016, 08:35:28 AM »
Thanks again Lee for all your great work & sharing with the community.  8)
steve.carson
« Reply #4 on: August 25, 2016, 11:31:39 AM »
I'm still learning my VL stuff, but did a dump on an attribute and it appears the property you want is Height, not TextHeight, so try:
GDF
« Reply #5 on: August 25, 2016, 12:07:16 PM »
Thanks Steve
That did the trick
« Reply #6 on: August 25, 2016, 03:12:01 PM »
All of these properties are also available by using vlax-dump-object, or in the developer help :)
