Author Topic: Surface - Referenced XML not found  (Read 3123 times)
Matt__W
  • I like my water diluted.
« on: August 23, 2016, 09:35:04 AM »
What's the best way to resolve this issue? The XML is from a surveyor and we don't have access to that file.
Autodesk Expert Elite
Re: Surface - Referenced XML not found
« Reply #1 on: August 23, 2016, 09:51:33 AM »
perhaps try changing the surface style to show points/triangles, contours
then extract those items and make a new surface or add them to the surface definition
OR
ask for the source surface xml
Matt__W
« Reply #2 on: August 23, 2016, 10:49:46 AM »
I exported the surface to LandXML then imported it back into the drawing, overwriting the existing surface and now I no longer get the error message AND the drawing opens much faster.
(side note: exporting/re-importing as a DEM produced very jagged contour lines)
Thanks for pointing me in the right direction, MJF.
« Reply #3 on: August 23, 2016, 11:27:23 AM »
consider that DEM is typically a GRID SAMPLED method
whereas you started with a TINN  (triangulated IRREGULAR network of nodes)
suggest that you not use DEM
