Author Topic: using COND  (Read 2977 times)
Zahex
using COND
« on: May 15, 2005, 06:20:02 PM »
Hey everybody!
I'm having a problem with my code because of the cond's.
I want that in the change question leads me to drawing the spiral but i can't do it...
What should i do?
(alert "To run type: Tatlin")
(defun c:spiral0 ()
  (command "layer" "new" "spiral0" "color" "53" "spiral0" "")
  (c:despiral)
  ) ; end defun
(defun c:despiral(param)()
(setq selec (entsel "Click in the solid where you want to draw the spiral:"))
  (setq spin -1); -1=CW, 1=CCW
  (setq ri (car param) rf (cadr param))
  (setq h (nth 2 param))
  (initget (+ 1 2 4))
  (setq ns (getint "number of spirals:" ))
  (setq tu (getreal "Number of turns: "))
  (setq rt (getreal "extrusion radius: "))
  (setq segs (nth 3 param))
  (setq old (getvar "osmode"))
  (setvar "cmdecho" 0)
  (setq fi1 (/ (* 2 PI) segs) i 0)
  (setq points (fix (* tu segs))
h1     (/ h points)
r1     (/ (- rf ri) points)
s      (last param)
  ) ;end setq
  (setvar "osmode" 0 )
  (command "3dpoly")
  (setq i 0)
  (repeat (1+ points)
    (setq fi (* i fi1) h (* i h1) r (+ ri (* i r1)))
    (setq x (* r (cos fi)) y (* spin r (sin fi)))
    (command (list (+ (car s) x) (+ (cadr s) y) (+ (caddr s) h)))
    (setq i (1+ i)))
  (command "")
  (setvar "osmode" old)
  (setq spiral (entlast))
  (command "ucs" "n" "za" (polar s 0 ri)
  (list
  (+(car s) (* ri (cos fi1)))
  (+(cadr s) (* spin ri (sin fi1)))h1))
  (command "circle" "0,0,0" rt)
  (command "extrude" (entlast) "" "p" spiral)
  (command "ucs" "p")
  (command "array" (entlast) "" "p" s ns 360 "y")
  (c:spiral0)
  ) ; end defun despiral
;;; Transformation question
(defun c:Question ()
  (command "zoom" "e")
  (setq answer (getstring "\n (c)hange ,e(x)it ou (r)estart?: "))
  (while (and (/= answer "c")
     (/= answer "x")
     (/= answer "r")
) ; and
"Only c,x ou r!: "
      ) ; getstring
    ) ; setq
  ) ;while
    ((= answer "c")(c:spiral))
    ((= answer "x"))
    ((= answer "r")(c:restart))
  ); defun
(defun c:solid ()
  (setq r1 (getdist "\n larger radius: ")
r2 (getdist "\n smaller radius: ")
h (getdist "\n height: ")
sides (getint "\n number of polygon sides: ")
centerpt (getpoint "\n insertion point: ")
osnaps (getvar "osmode")
ang (atan (* (/ (- r1 r2) h) (cos (/ PI sides))))
  ) ; end setq
  (setvar "osmode" 0)
  (command "polygon"
  sides
  centerpt
  "I"
  (polar centerpt 0 r1)
  (command "extrude" (entlast) "" h (/ (* ang 180.0) pi ))
  (setvar "osmode" osnaps)
  (list r1 r2 h sides centerpt)
  (command "zoom" "ex")
 (c:Question)
) ;end defun solid
  ;;; initial function
(defun c:Tatlin ()
  (c:solid)
) ;defun
using COND
« Reply #1 on: May 15, 2005, 07:46:41 PM »
Something like this:
  (initget 1 "Change eXit Restart")
  (setq answer (getkword "\n Enter option: [Change/eXit/Restart] "))
    ((eq answer "Change")(c:spiral))
    ((eq answer "eXit"))
    ((eq answer "Restart")(c:restart))
  ); defun
Zahex
there's something wrong with change option
« Reply #2 on: May 15, 2005, 07:54:40 PM »
there's something wrong with change option:
 insertion point:
 Enter option: [Change/eXit/Restart] c
; error: too few arguments
Command: 'VLIDE
Command:
Why does this happens?
using COND
« Reply #3 on: May 15, 2005, 08:05:42 PM »
Well you need to debug your code.
the function: (defun c:despiral(param)()
is looking for a value passed to the routine, in this case the param.
If you know the value of the param you need to pass it but the function must be
(defun despiral(param) not (defun c:despiral(param) to accept a value passed.
and the new call will be
(defun c:spiral0 ()
  (setq param <to the value you want to use>)
  (despiral param)
  ) ; end defun
  Did you follow that explanation?
Jürg Menzi
  • Oberegg, Switzerland
using COND
« Reply #4 on: May 16, 2005, 09:49:53 AM »
What I would do...
(defun spiral0 (Pnt)
 (command "_.layer" "_new" "spiral0" "_color" "53" "spiral0" "")
 (despiral Pnt)
 T
) ; end defun
(defun despiral (Pnt / spin ns tu rt old fi1 i points h h1 r1 fi r x y spiral)
;;; (setq selec (entsel "Click in the solid where you want to draw the spiral:")) ;????
  ((and
    (not (initget (+ 2 4)))
    (not (setq ns (getint "\n Number of spirals <exit>:" )))
   nil
  ((and
    (not (setq tu (getreal "\n Number of turns <exit>: ")))
   nil
  ((and
    (not (setq rt (getreal "\n Extrusion radius <exit>: ")))
   nil
  (T
   (setq fi1    (/ (* 2 pi) Me:Sds)
         i      0
         points (fix (* tu Me:Sds))
         h1     (/ Me:Hgt points)
         r1     (/ (- Me:Srd Me:Lrd) points)
   (command "_.3dpoly")
   (repeat (1+ points)
    (setq fi (* i fi1)
          h  (* i h1)
          r  (+ Me:Lrd (* i r1))
          x  (* r (cos fi))
          i  (1+ i)
    (command (list (+ (car Pnt) x) (+ (cadr Pnt) y) (+ (caddr Pnt) h)))
   (command "")
   (command "_.ucs" "_n" "_za"
            (polar Pnt 0 Me:Lrd)
            (list
             (+ (car Pnt) (* Me:Lrd (cos fi1)))
             (+ (cadr Pnt) (* spin Me:Lrd (sin fi1)))
             h1
            "_.circle" '(0 0 0) rt
            "_.extrude" (entlast) "" "_p" spiral
            "_.ucs" "_p"
            "_.array" (entlast) "" "_p" Pnt ns 360 "_y"
   T
(defun Question (Pnt / Answer)
 (command "_.zoom" "_e")
 ;;;CAB's sample:
 (setq Answer (getkword "\n Enter option [Change/eXit/Restart]: "))
  ((eq Answer "Change") (spiral0 Pnt)) ;<- There is no function with the name 'spiral'!!!
  ((eq Answer "eXit") T)
  ((eq Answer "Restart") nil)
); end defun Question
(defun c:Tatlin ( / CenPnt CurAng ExLoop OldOsm TmpPmt)
 (while (not ExLoop)
   ((not (setq CenPnt (getpoint "\n Insertion point: ")))
    (setq ExLoop T)
   ((and
     (setq TmpPmt (if Me:Lrd
                   (strcat "\n Larger radius <" (rtos Me:Lrd) ">: ")
                   "\n Larger radius: "
     (not (setq Me:Lrd (cond ((getdist CenPnt TmpPmt)) (Me:Lrd))))
    (setq ExLoop T)
   ((and
     (setq TmpPmt (if Me:Srd
                   (strcat "\n Smaller radius <" (rtos Me:Srd) ">: ")
                   "\n Smaller radius: "
     (not (setq Me:Srd (cond ((getdist CenPnt TmpPmt)) (Me:Srd))))
    (setq ExLoop T)
   ((and
     (setq TmpPmt (if Me:Hgt
                   (strcat "\n Height: <" (rtos Me:Hgt) ">: ")
                   "\n Height: "
     (not (setq Me:Hgt (cond ((getdist CenPnt TmpPmt)) (Me:Hgt))))
    (setq ExLoop T)
   ((and
     (setq TmpPmt (if Me:Sds
                   (strcat "\n Number of polygon sides: <" (itoa Me:Sds) ">: ")
                   "\n Number of polygon sides: "
     (not (setq Me:Sds (cond ((getint TmpPmt)) (Me:Sds))))
    (setq ExLoop T)
   (T
    (setq OldOsm (getvar "osmode")
          CurAng (atan (* (/ (- Me:Lrd Me:Srd) Me:Hgt) (cos (/ pi Me:Sds))))
    (setvar "osmode" 0)
    (command "_.polygon" Me:Sds CenPnt "_I" (polar CenPnt 0 Me:Lrd))
    (command "_.extrude" (entlast) "" Me:Hgt (/ (* CurAng 180.0) pi))
    (setvar "osmode" OldOsm)
    (command "_.zoom" "_ex")
    (setq ExLoop (Question CenPnt))
) ;end defun Tatlin
Cheers
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
Zahex
using COND
« Reply #5 on: May 16, 2005, 10:36:17 AM »
Hey Jurg!
Thanks for replying...There's only one thing:instead of appearing,couldn't the spirals be drawn when http://clicking the solid previously drawn?
Zahex
using COND
« Reply #6 on: May 16, 2005, 10:38:54 AM »
Hi CAB:
Sorry not saying anything yesterday but right after i received your message my internet fell and i couldn't get in untill now..
Actually i didn't understood your explanation,could you try to explain it to me once more,please?
Jürg Menzi
using COND
« Reply #7 on: May 17, 2005, 02:44:07 AM »
Hi
Quote from: Zahex
(...)There's only one thing:instead of appearing,couldn't the spirals be drawn when http://clicking the solid previously drawn?
AFAIK, you've no direct access to the solid geometrie...
Cheers
