I'd use polar tracking & check relative to last segment.
Quote from: ronjonp on August 10, 2016, 02:38:06 PMI'd use polar tracking & check relative to last segment.Thank you my friend Ron! Fabricio
Quote from: FABRICIO28 on August 10, 2016, 02:55:12 PM Quote from: ronjonp on August 10, 2016, 02:38:06 PMI'd use polar tracking & check relative to last segment.Thank you my friend Ron! FabricioGlad to help
Use the 'Additional Angles' section of the Polar Tracking dialog.You may also find it useful to increase APERTURE such that the polar tracking angles are acquired with greater sensitivity.
Don't you just need to add 11.25?
Strange .. the angles I use for fittings are 11.25 , 22.5, 45 & 90 all are divisible by 11.25 ??It looks like an easy way to set the used angle is through (setvar 'polarang (angtof "11.25")), then in the options you see:
Quote from: ronjonp on August 11, 2016, 11:43:46 AMStrange .. the angles I use for fittings are 11.25 , 22.5, 45 & 90 all are divisible by 11.25 ??It looks like an easy way to set the used angle is through (setvar 'polarang (angtof "11.25")), then in the options you see:..Can I set Polar Tracking just for some angles?Because there are some angles that I don't wanna use, like 34°...
Quote from: FABRICIO28 on August 11, 2016, 12:35:35 PMQuote from: ronjonp on August 11, 2016, 11:43:46 AMStrange .. the angles I use for fittings are 11.25 , 22.5, 45 & 90 all are divisible by 11.25 ??It looks like an easy way to set the used angle is through (setvar 'polarang (angtof "11.25")), then in the options you see:..Can I set Polar Tracking just for some angles?Because there are some angles that I don't wanna use, like 34°...Try this: (setvar 'polarang (angtof "11.25")) & make sure you have relative to last segment checked.Look into POLARADDANG, POLARMODE & POLARANG variables.
I'm lost on what you're really trying to accomplish .. sorry.
Why not set incremental angle to 90° and add 11°, 22° and 45° as additional angles? //Also this isn't really an AutoLISP question as it is a CAD General...
proof of concept attached.You might want to also add the following angles -> 349, 328, 315. This will allow you to go both directions from the last point.
Set your increment angle to 90° and add the 6 additional angles. 11, 22, 45, 315, 328, 349. Granted 180 and 270 will be options but unless you want to go a lisp routine I don't think you can set additional angles without incremental angles.
When relative to UCS is enabled, the last two points determine 0°. If 11/22/45 are your only options, the poly line will only go counter clockwise.
Quote from: Master_Shake on August 12, 2016, 09:21:17 AMWhen relative to UCS is enabled, the last two points determine 0°. If 11/22/45 are your only options, the poly line will only go counter clockwise.Isn't that why we're using relative to last segment? .. Either way what you told him seems to solve the problem .. I just do it differently
