Author Topic: Custom Sheet View Field  (Read 2134 times)
Fabricio28
« on: August 09, 2016, 03:43:56 PM »
Hi friends!
How are you?
I'm trying to create a field to layout number.
Anybody Can help me, please?
Fabricio
ChrisCarlson
Re: Custom Sheet View Field
« Reply #1 on: August 09, 2016, 03:54:26 PM »
SHEETNUMBER = CurrentSheetNumber
Fabricio28
« Reply #2 on: August 09, 2016, 03:58:49 PM »
Hi
Isn't working for me.
Could you please attached a dwg as a example?
ChrisCarlson
« Reply #3 on: August 09, 2016, 04:16:25 PM »
Load the DWG into the SSM and then re-insert the block.
« Reply #4 on: August 09, 2016, 05:09:19 PM »
What I advise most, is that when creating/testing Sheet Set Fields the Best Practice is to create a 'dummy' sheet set.
This can then later be used as one's Example Sheet Set ... After all your fields have been defined and tested.
Fabricio28
« Reply #5 on: August 10, 2016, 06:58:08 AM »
It isn't working for me. I don't know how to use SSM.
Could you give a help, please?
Sorry guys. I get it!
I'm going to study about SSM, it is a powerful tool.
Thank in advance
Fabricio
« Last Edit: August 10, 2016, 07:19:31 AM by FABRICIO28 »
