Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Corridor Elevations Not Matching Alignment?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Corridor Elevations Not Matching Alignment? (Read 1406 times)
dpatterson
Guest
on:
August 08, 2016, 11:41:20 AM »
Hi Everyone,
I was hoping I could get some help. I built a simple corridor along an alignment, but when i create a surface from the corridor and check the elevations at each station they are off? They do not seem to be off by a constant value. Is there a way to make the corridor model the profile alignment closer or correct this issue.
For example: station 100 profile = 95.054
station 100 corridor surface check = 94.680
It should be equal to profile.
Thanks for your Help!
_David
Logged
King Gator
C3D user & customizer
Re: Corridor Elevations Not Matching Alignment?
Reply #1 on:
August 08, 2016, 08:50:05 PM »
David, can you post your dwg file? If not, double check the objects which make up the surface, make sure the subassemblies aren't offset from the assembly insertion, etc.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
