Author Topic: How to get List of all Files on a FTP Page  (Read 4836 times)
mailmaverick
« on: August 06, 2016, 08:23:41 AM »
How to get List of all Files on a FTP Page through autolisp ?
ChrisCarlson
Re: How to get List of all Files on a FTP Page
« Reply #1 on: August 08, 2016, 08:11:29 AM »
Didn't think it was possible to upload / download BUT
  1. ;;https://www.theswamp.org/index.php?topic=43337.msg485805#msg485805
  2.   "ftp://user:password@ftp.domain.com//public//sites//www.domain.com//files//"
  3.   "c:\\test.dwg"
  4. )
For a list of files, that would mainly be dependent on the FTP server if it allows say "site list"
mailmaverick
« Reply #2 on: August 09, 2016, 11:09:25 AM »
Thanks for your reply but I need to get list of files, not put any file.
Also site list is allowed and there is no username and password.
dgorsman
« Reply #3 on: August 09, 2016, 03:48:00 PM »
Is this some specific location, or just fishing on any random one?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
mailmaverick
« Reply #4 on: August 11, 2016, 03:32:36 PM »
There is my company's internal intranet which I want to explore through LISP.
« Reply #5 on: August 11, 2016, 03:40:23 PM »
If it's internal, why do you need FTP?
VovKa
  • Ukraine
« Reply #6 on: August 11, 2016, 05:07:30 PM »
wget --no-remove-listing ftp://ftp.opera.com/pub/opera/win/1218/en/
wget will create file .listing in its folder
just read it and parse the contents
get it http://gnuwin32.sourceforge.net/packages/wget.htm
mailmaverick
« Reply #7 on: August 11, 2016, 06:29:45 PM »
Internal means company's files are stored on  a FTP server for use by various people.
« Reply #8 on: August 12, 2016, 09:52:28 AM »
Gotcha .. so hosted storage.
mailmaverick
« Reply #9 on: August 14, 2016, 12:35:41 PM »
Thanks Vovka for wget but is it possible in LISP ?
I dont want to modify or put any file but just want list (directory listing) of files.
Please help.
VovKa
  • Ukraine
« Reply #10 on: August 14, 2016, 01:51:11 PM »
i don't know any means to do this without extra components
PKENEWELL
« Reply #11 on: August 15, 2016, 03:10:41 PM »
Why not use a Shell interface with the command-line FTP command with DIR and -s:filename? I do not have an FTP to test, but if you could send me an example that I could access, I could give it a try and see if it works.
http://www.nsftools.com/tips/MSFTP.htm
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
mailmaverick
« Reply #12 on: August 15, 2016, 10:56:42 PM »
Following example can be used :
ChrisCarlson
« Reply #13 on: August 16, 2016, 08:04:43 AM »
This is probably your best bet.
PKENEWELL
« Reply #14 on: August 16, 2016, 09:58:12 AM »
Hmmm. I used NSLOOKUP to get the IP address as required (correction - you can also use a domain) by the FTP program "open" command. I am able to connect to the server you gave, but it will not allow the DIR command unless I "login with USER and PASS". I did not think there was any login requirement. Well - In theory, you should be able to use a Batch file, and direct the output to a text file then read the file back in to a variable in AutoLISP. If you can figure out the proper way to get the info using the FTP command and give me the sequence in a batch file, I will try writing you a routine to run it and retrieve the output.
« Last Edit: August 16, 2016, 10:09:06 AM by PKENEWELL »
ChrisCarlson
« Reply #15 on: August 16, 2016, 10:27:07 AM »
[1] site list
[1] 550 Permission denied.
PKENEWELL
« Reply #16 on: August 16, 2016, 01:54:05 PM »
OK - got this working. It's clunky and slow but it does what the OP wants. Change the variables for paths and ftp information to fit the server and directory needed. NOTE: for some reason, you cannot save the batch file in the same directory as the runftp.txt script or results. it starts an endless loop. I don't know why it would do that.
(Not much for Error checking in this - alter as you will)
(defun c:testFTP (/ bpth pth2 ftp ftpp usrn pswd fl wscript cmd exec res rtn)
   (setq bpth "c:\\users\\philk\\"
         pth2 "c:\\users\\philk\\documents\\"
         ftp "ftp.opera.com"
         ftpp "/pub/opera/win/1218/en/"
         usrn "anonymous"
         pswd "myemail@email.com"
   (setq fl (open (strcat bpth "FTP.BAT") "w"))
   (write-line "REM Set the working path" fl)
   (write-line (strcat "cd " pth2) fl)
   (write-line "" fl)
   (write-line "REM Write a Script to run the FTP commands" fl)
   (write-line (strcat "echo open " ftp "> runftp.txt") fl)
   (write-line (strcat "echo user " usrn " " pswd ">> runftp.txt") fl)
   (write-line (strcat "echo cd " ftpp ">> runftp.txt") fl)
   (write-line (strcat "echo dir -r " pth2 "ftpdir.txt>> runftp.txt") fl)
   (write-line "echo bye>> runftp.txt" fl)
   (write-line "" fl)
   (write-line "REM Launch FTP and pass it the script" fl)
   (write-line "ftp -n -s:runftp.txt" fl)
   (write-line "" fl)
   (write-line "REM Clean up." fl)
   (write-line "del runftp.txt" fl)
   (close fl)
   (if (setq wscript (vlax-create-object "WScript.Shell")
             cmd (findfile (strcat bpth "FTP.BAT"))
           (setq exec (vlax-invoke wscript 'Exec cmd))
           (while (and exec (= 0 (vlax-get-property exec 'Status)))
                  (princ (strcat "\rWaiting for Program \"" cmd "\"..."))
           (mapcar 'vlax-release-object (list exec wscript))
   (if (setq res (findfile (strcat pth2 "ftpdir.txt")))
         (setq fl (open res "r"))
         (while (setq ln (read-line fl))
            (princ (strcat "\n" ln))
            (setq rtn (reverse (cons ln (reverse rtn))))
         (close fl)
   (princ "\n\n")
   rtn
« Last Edit: August 16, 2016, 03:38:36 PM by PKENEWELL »
Andrea
« Reply #17 on: August 20, 2016, 03:10:05 PM »
did you tried to map a simple drive to the FTP site with windows..and then....read the file normaly ?
Keep smile...
PKENEWELL
« Reply #18 on: August 22, 2016, 01:16:17 PM »
Yes Interesting :idiot2: :-). I hadn't considered that since I haven't used FTP in ages. Seems like a sensible approach to me. The only drawback is depending on local drive mappings, which in a large user base can be difficult if all mappings are not forced to be the same. If a large company CAD base, the OP or his IT admin would also have to make a login script to establish all the drive mappings to a letter that (hopefully) isn't already mapped by someone. If the OP's CAD user base is relatively small though, it could be relatively easy to setup per user.
