Author Topic: vl-registry-write  (Read 5398 times)
cadman6735
vl-registry-write
« on: July 28, 2016, 11:31:48 AM »
I was watching an AU video where the instructor edited his registry to point PSETUPIN to open his dialog box to a default specific folder of his choosing each and everytime.  I can't seem to get it to work.  here is the code I copied from a screen capture.  On my computer at home the code edited the registry but the dialog never defaulted to that location.  I am using AutoCAD 2002 at home, so thinking I need a newer version, I tried it here at work on a crap machine for testing stuff with AutoCAD 2015, I can't even get the registry to update, so I manually changed the Registry to my desired location but still no go, it does not default to this desired location.  I am very interesting in learning how to manipulate the registry and control my default dialog boxes.
Can someone explain to me and point me to some good examples and tutorials, etc...
[/(vl-load-com)
(vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profile\\" (getvar "cprofile") "\\Dialogs\\PSETUPNavDlg") "FileNameMRU0" "C:\\Autodesk\\Publish_Template.dwt")
(vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profile\\" (getvar "cprofile") "\\Dialogs\\PSETUPNavDlg") "InitialDirectory" "C:\\Autodesk")code]
« Last Edit: July 28, 2016, 11:47:42 AM by cadman6735 »
ChrisCarlson
Re: vl-registry-write
« Reply #1 on: July 28, 2016, 12:02:55 PM »
Actually, I wouldn't mess with the registry. I think you need to restart AutoCAD for it to see the changes to the registry.
Look into "PlotToFilePath"
(setenv "PlotToFilePath" locationasstring)
« Reply #2 on: July 28, 2016, 12:18:41 PM »
Wouldn't your pagesetups be static? You could set filedia to 0 then run (vl-cmdf ".-psetupin" fulltemplatepath "*") to automagically import them.
Here'a a stripped down version of a routine I've used for year that you could modify.
  1. (defun c:page (/ path)
  2.   ;; Delete all pagesetups first
  3.     (vla-delete x)
  4.   )
  5.   ;; Import if file is found
  6.   (if (findfile (setq path "C:/Your/Path/YourTemplate.dwt"))
  7.     (progn (setvar 'filedia 0)
  8.       (vl-cmdf ".-psetupin" path "*")
  9.       (princ "\n <<<Pagesetups Imported>>>")
  10.       (setvar 'filedia 1)
  11.     )
  12.     (princ "\n <<<AAAAAGGGGGHHHH!!!!! .. Pagesetups NOT FOUND!>>>")
  13.   )
  14.   (princ)
  15. )
« Last Edit: July 28, 2016, 12:31:26 PM by ronjonp »
cadman6735
« Reply #3 on: July 28, 2016, 12:25:11 PM »
Hi mater shake, I did restart my autocad, but it didn't update.  Thanks anyway.
I respect the notion of not messing with the registry, but the tools are there and I see some desired results, I am interested in learning and wanting to understand, not to be discouraged.
Hi RonJon,  yes, I am already importing them,
I just saw a new trick that I feel I can expand upon and wanting to understand why the code is not working and hoping to find a new path of information by asking.
« Reply #4 on: July 28, 2016, 12:32:07 PM »
I updated my post above to include some code.
cadman6735
« Reply #5 on: July 28, 2016, 12:39:43 PM »
I have some code similar to yours, that I believe CAB helped me with years ago,  but when I place it in a sub folder and have my AutoLoad.lsp try to load it, it errors.  But when I place it in the main folder as my autolaod.lsp, not an issue...  I can't figure out why, and I hate having it outside of my macro folder, just seems so out of place.
(defun PageSetup_AutoLoad (/)
; Load Plot Page Setup from Template file
  (setq *path* "S:\\VDC Library\\AutoCAD\\User Interface\\Plotters\\Publish\\"
*file* "Publish_Template.dwg"
*pathfile* (strcat *path* *file*)
    (findfile *pathfile*)
      (command "._psetupin" *pathfile* "*")
      (while (wcmatch (getvar "cmdnames") "*PSETUPIN*") (command "_y"))
)(PageSetup_AutoLoad)
« Reply #6 on: July 28, 2016, 01:45:08 PM »
Maybe you need to deal with trusted file locations.
cadman6735
« Reply #7 on: July 28, 2016, 01:59:34 PM »
I have my secure loaded turned off (setvar "SecureLoad" 0) and my autoload loads all my other macros but this one, so it's not that.  I also believe, because you said that, you have clued me into another issue I am having, so thanks
Anyway this is all off topic, I am interested in learning about the registry environment and why the code I supplied does not work.
Where I want to grow with this is to control default start locations for when dialog boxes open, they start somewhere and remember the last place they where at when opening, and I want to have some control over this.
ChrisCarlson
« Reply #8 on: July 28, 2016, 02:01:18 PM »
« Reply #9 on: July 28, 2016, 02:13:22 PM »
« Reply #10 on: July 28, 2016, 02:14:57 PM »
Are you an admin on your computer? Perhaps you don't have write access to the registry.
dgorsman
« Reply #11 on: July 28, 2016, 02:18:09 PM »
Could also be UAC protecting the computer from the user.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
cadman6735
« Reply #12 on: July 28, 2016, 02:40:55 PM »
Thanks for the link to the code, Shake Master and RonJon, very helpful.  The code I supply is pathing the same as Ron's only difference I see is where I have "FileNameMRU0" and "InitialDirectory" where Ron seems to be only using "InitialDirectory" on most and "(Default)" "Initialdirectory" "FileNameMRU0" in conjunction with others.  So I may not be using it right in conjunction with each other.  I will experiment to see what I can learn.
RonJon, when you wrote that macro, where did you get the info to tell you what each registry name meant and how to use it?  example:  "InitialDirectory" "(Default)" "FileNameMRU0"
I am also wondering if I have admin rights to the registry myself, AutoCAD can't make the change via lisp, but I can manually change the registry.  But it still does not update my autoCAD after manual update, how will I know if I have rights to write to it.  It say I have full control but it is greyed out.
I have only experimented with PSETUPNavDlg so the code may not even be correct for the specific one.
« Reply #13 on: July 28, 2016, 02:48:00 PM »
To be honest I don't really remember. I think it was just a bunch of searching the registry for keys that changed & wrote the lisp to modify the same keys.  :oops:
« Reply #14 on: July 28, 2016, 03:03:13 PM »
In 2017, the key to modify is this:
  1. (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profile\\" (getvar "cprofile") "\\Dialogs\\Select Page Setup From File") "InitialDirectory" "C:\\Autodesk\\")
I don't have a 'PSETUPNavDlg' key?
