Author Topic: GUID named textstyles  (Read 1864 times)
Jeff H
« on: July 27, 2016, 12:45:12 PM »
Does anyone know where the GUID named Textstyles come from or why they are created? Usually see them when purging a drawing.
If not familiar with GUID the textstyles will be named something like
{e77b0145-31ec-48a1-8b81-9e9108c45f3b}
ChrisCarlson
Re: GUID named textstyles
« Reply #1 on: July 27, 2016, 01:26:49 PM »
Start with a new clean drawing, initialize bedit and close out without saving. Does it appear?
Jeff H
« Reply #2 on: July 27, 2016, 01:44:41 PM »
Not sure I follow but initialized BEDIT in clean drawing, and only could open <current drawing> but closed without saving and nothing was added.
ChrisCarlson
« Reply #3 on: July 27, 2016, 02:00:36 PM »
For a while (thought it was similar) if you started the BEDIT command a GUID-esque text style was created.
Jeff H
« Reply #4 on: July 27, 2016, 02:03:42 PM »
I think it happens after ATTSYNC maybe.
dgorsman
« Reply #5 on: July 27, 2016, 04:56:43 PM »
As far as I can tell its to do with using the BEDIT environment and dynamic blocks.
Edit: BEDIT on a blank drawing, added a couple of lines and a move; saved and tested; BCLOSE to return with saving changes.  And there's the text style in the purge dialog.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
