Author Topic: AutoCAD 2017 SP1 warning  (Read 6182 times)
rkmcswain
« on: July 25, 2016, 08:37:03 AM »
Jimmy Bergmark from JTB World, has reported that the just released SP1 for AutoCAD 2017 breaks the functionality of the "plug-in auto loader mechanism". Please make note of this before installing SP1, which is currently only available via the Autodesk Desktop App. References below:
Ref 1: AutoCAD 2017 Service Pack 1 and a word of warning
Ref 2: AutoCAD 2017 Service Pack 1 is out but you probably don’t want to install it
« Last Edit: July 25, 2016, 08:46:29 AM by rkmcswain »
Rob...
Re: AutoCAD 2017 SP1 warning
« Reply #1 on: July 25, 2016, 08:40:03 AM »
Don't know if it's an internal issue, but none of those links work for me.
CAD Tech
huiz
  • Certified Prof C3D
« Reply #2 on: July 25, 2016, 09:53:18 AM »
Just tested but the auto loader mechanism is not broken here.
rkmcswain
« Reply #3 on: July 26, 2016, 08:13:56 AM »
Interesting. I wonder if there are some other circumstances at play here?
huiz
« Reply #4 on: July 26, 2016, 09:16:22 AM »
Ok, a few more tests.
Another computer, just installed SP1 and only 1 of 8 plugins got loaded.
In Civil 3D the plugins get loaded but not in AutoCAD.
As far as I understand the plugins are not loaded if the PackageContents.xml contains this
SeriesMin="R21.0" SeriesMax="R21.0"
If you remove this, the plugin will load but that is not a solution of course. I'll log this bug.
« Last Edit: July 26, 2016, 09:47:35 AM by huiz »
rkmcswain
« Reply #5 on: July 26, 2016, 09:30:32 AM »
Nice. Thanks for the update.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #6 on: July 26, 2016, 10:13:00 AM »
Has SP1 been made unavailable  ??
Called Kerry in my other life
I live at UTC + 13.00
rkmcswain
« Reply #7 on: July 26, 2016, 10:18:00 AM »
No, it's still available on the Autodesk App.
« Reply #8 on: July 26, 2016, 10:26:58 AM »
OOPS, SORRY RON ... I modified instead of quoting ... time for bed.
I was wondering the same thing .. seems odd that you could not get it HERE.
That was second for me.
First was my ADN Subscription interface.
No joy on either .... hence the query
« Last Edit: July 26, 2016, 10:33:07 AM by kdub »
rkmcswain
« Reply #9 on: July 26, 2016, 10:29:47 AM »
It seems like they are releasing updates, SP, etc. on the app first, then later on the support site. Probably to entice users to start using the app.
BlackBox
« Reply #10 on: July 26, 2016, 11:05:29 AM »
Can anyone confirm 'Edit & Continue' being fixed with 2017 SP1?
rkmcswain
« Reply #11 on: July 26, 2016, 11:59:03 AM »
'Edit & Continue'
Elaborate on this?
BlackBox
« Reply #12 on: July 26, 2016, 12:08:46 PM »
« Reply #13 on: July 26, 2016, 09:06:54 PM »
Yes, E & C now works. And I have found, too, that the bundles I have still load fine with C3D2017.
huiz
« Reply #14 on: July 27, 2016, 02:14:23 PM »
Autodesk has confirmed that they are aware of the bug and they promise to create a hotfix as soon as possible...
