Author Topic: Group - empty or not?  (Read 1187 times)
Peter2
« on: July 21, 2016, 05:26:43 AM »
I need a way to define if a group (for example named "test") is empty or not.
I found a way to handle not-empty groups, but there are problems when they are empty:
(command "_.select" "_group" "test" "")
; -> returns always nil for empty and not-empty groups
(setq aws (ssget "_P"))
;-> Problem: "_P" are the elements of the not-empty group OR (if empty) some other "previous seöections"
I'm sure that there is a simple way which someone can show me ...
Peter
BricsCAD V23
Peter2
Re: Group - empty or not?
« Reply #1 on: July 21, 2016, 05:47:21 AM »
Peter
BricsCAD V23
Marc'Antonio Alessi
  • Marco
« Reply #2 on: July 22, 2016, 07:45:56 AM »
; remove null groups and one entity groups too
; (ALE_Utl_PurgeGroups *AcAcDwg*)
(defun ALE_Utl_PurgeGroups (DbxDoc / VlaObj Countr)
  (setq Countr 0)
  (vlax-map-Collection
    (setq VlaObj (vla-get-groups DbxDoc))
   '(lambda (LmbDat)
      (or
        (< 1 (vla-get-count LmbDat))
          (vla-delete LmbDat)
          (setq Countr (1+ Countr))
  (or
     (zerop Countr)
     (princ (strcat "\n" (itoa Countr) " unreferenced groups purged. "))
  (vlax-release-object VlaObj)
