Author Topic: Problem with the previous selection set  (Read 5295 times)
Lupo76
« on: July 21, 2016, 01:56:56 AM »
Hello to all,
I hope to be able to explain my problem.
I inserted an object reactor that intervenes every time I move an object.
But by performing the following steps I have a problem:
  • Start the MOVE command and pick any object and conclude the movement
  • Then start again the MOVE command (or COPY / MIRROR) and when prompted to select the objects I type "p" to select the object of the first step.
Unfortunately, the selection group of the second step, contains unwanted objects definitely coming from the reactor processing.
I have noticed that this happens because I used inside the reactor (ssget "X" ......)
How can I avoid this?
I thought I'd save in a variable the selection of the first step group and restore it in the "previous selection set" (the option "P"); but I need your help to do this.
Thanks in advance.
« Last Edit: July 21, 2016, 02:22:16 AM by Lupo76 »
Marc'Antonio Alessi
  • Marco
Re: Problem with the previous selection set
« Reply #1 on: July 21, 2016, 03:13:57 AM »
Try to pass an ssget with filter: (ssget "_P" '((-3 ...))).
Lupo76
« Reply #2 on: July 21, 2016, 03:45:57 AM »
This can not work.
I intend to use the P option using the native commands of the cad (no lisp):
Command: MOVE
Select objects: Specify opposite corner: 1 found
Select objects:
Specify base point or [Displacement] <Displacement>:
Specify second point or <use first point as displacement>:
Command: _MOVE
Select objects: p   <----------------------------
1 found
I would that the selection group of the P option is the same as indicated by the user before the reactor and not that of the function (ssget "X" ...) present in the reactor.
roy_043
  • BricsCAD 18
« Reply #3 on: July 21, 2016, 07:44:55 AM »
The best advice I can give you is: Do not use ssget in your callback function. There must be a better (more efficient) way to achieve what you want.
One way to 'restore' the "_P" selection set is something like this:
  1. (defun c:test ( / ss1 ss2)
  2.   (setq ss1 (ssget))
  3.   (setq ss2 (ssget "_X"))
  4.   (KGA_Sys_VarStackPush '((grips 0) (highlight 0))) ; Store old and apply new values.
  5.   (sssetfirst nil ss1)
  6.   (ssget "_I")
  7.   (KGA_Sys_VarStackPop) ; Restore old values.
  8.   (princ)
  9. )
But I have my doubts if it will work inside a reactor callback. In BricsCAD using (sssetfirst) is problematic in that context, but maybe this does not apply to AutoCAD.
I am not including the push/pop functions. You probably have your own anyway.
ChrisCarlson
« Reply #4 on: July 21, 2016, 07:59:03 AM »
This can not work.
Command: MOVE
Select objects:
Command: _MOVE
1 found
I'm confused, you intend to use native cad commands (possibly scripts?) without LISP but you are using reactors and ssget?
Are you basically moving object A from location A to B, starting the command again and moving object A from location B to C?
Lupo76
« Reply #5 on: July 21, 2016, 08:37:14 AM »
Yes exactly I need to move the same objects from A to B and then from B to C.
But I could also move the same objects from A to B and then copy them from A to C.
To do this I often use the "P" option to not be forced to re-select all items again.
Lupo76
« Reply #6 on: July 21, 2016, 08:44:41 AM »
Do you have some practical advice about this?
Here where I use (ssget "X"...)
(defun SelWithID (ID typeobj / seleztmp selez ent1 n thexdata)
  (setq selez (ssget "X" (list (cons 0 typeobj)(list -3 (list "MYAPP")))))
  (setq seleztmp (ssadd))
  (if selez
      (setq n 0)
      (repeat  (sslength selez)
        (setq ent1 (ssname selez n)
              n (1+ n)
        (setq thexdata (cdr (car (cdr (assoc -3 (entget ent1 (list "MYAPP")))))))
        (foreach el thexdata
          (if (= (cdr el) (strcat "ID=" ID))
            (ssadd ent1 seleztmp)
  (if (= (sslength seleztmp) 0)
    nil
    seleztmp
  6.   (ssget "_I")
  8.   (princ)
  9. )
I use also BricsCAD :-(
Can you also send me these functions?
roy_043
  • BricsCAD 18
« Reply #7 on: July 21, 2016, 12:18:41 PM »
It seems that you application works with groups of objects that share a common ID. Why don't you store references to all the entities in the group in your Xdata? That would be my approach. For functions that I use to format Xdata see here.
    -3
      "MYAPP"
      (1002 . "{")
      (1002 . "{")
      (1000 . "GROUP_ID")
      (1005 . "ABC123")
      (1002 . "}")
      (1002 . "{")
      (1000 . "OBJECTS_IN_GROUP")
      (1002 . "{")
      (1005 . "...")
      (1005 . "...")
      (1005 . "...")
      (1002 . "}")
      (1002 . "}")
      (1002 . "}")
« Last Edit: July 21, 2016, 12:35:35 PM by roy_043 »
roy_043
  • BricsCAD 18
« Reply #8 on: July 21, 2016, 12:35:20 PM »
... I have done a few (but only a few) more tests, and it would seem that code similar to the previously posted function *does* work inside a callback function.
So it is worth trying this:
  1. (defun SelWithID (ID typeobj / selezPre seleztmp selez ent1 n thexdata)
  2.   ;; Start new code
  3.   (setq selezPre (ssget "_P"))
  4.   ;; End new code
  5.   (setq selez (ssget "X" (list (cons 0 typeobj)(list -3 (list "MYAPP")))))
  6.   ;; Start new code
  7.   (KGA_Sys_VarStackPush '((grips 0) (highlight 0))) ; Store old and apply new values.
  8.   (sssetfirst nil selezPre)
  9.   (ssget "_I")
  10.   (KGA_Sys_VarStackPop) ; Restore old values.
  11.   ;; End new code
  12.   (setq seleztmp (ssadd))
  13.   (if selez
  14.     (progn
  15.       (setq n 0)
  16.       (repeat  (sslength selez)
  17.         (setq ent1 (ssname selez n)
  18.               n (1+ n)
  19.         )
  20.         (setq thexdata (cdr (car (cdr (assoc -3 (entget ent1 (list "MYAPP")))))))
  21.
  22.         (foreach el thexdata
  23.           (if (= (cdr el) (strcat "ID=" ID))
  24.             (ssadd ent1 seleztmp)
  25.           )
  26.         )
  27.       )
  28.     )
  29.   )
  30.   (if (= (sslength seleztmp) 0)
  31.     nil
  32.     seleztmp
  33.   )
  34. )
  35.
  36. (defun KGA_Sys_VarStackPush (lst)
  37.   (setq *sys_varStack*
  38.     (cons
  39.       (mapcar
  40.         '(lambda (a / old)
  41.           (setq old (getvar (car a)))
  42.           (if (cadr a) (setvar (car a) (cadr a)))
  43.           (list (car a) old)
  44.         )
  45.         lst
  46.       )
  47.       *sys_varStack*
  48.     )
  49.   )
  50. )
  51.
  52. (defun KGA_Sys_VarStackPop ()
  53.   (mapcar
  54.     '(lambda (a)
  55.       (setvar (car a) (cadr a))
  56.     )
  57.     (car *sys_varStack*)
  58.   )
  59.   (setq *sys_varStack* (cdr *sys_varStack*))
  60. )
Edit: Switched back to Lisp-based push/pop functions. Simplified versions of these functions are now included.
« Last Edit: July 21, 2016, 04:48:40 PM by roy_043 »
Lupo76
« Reply #9 on: July 21, 2016, 01:07:14 PM »
Your advice is very interesting and definitely will greatly increase the performance of my application!
It will take a long time to implement it but I'm sure in the next few weeks I will do this ;-)
Lupo76
« Reply #10 on: July 21, 2016, 01:13:19 PM »
As you can see I have used acet-sysvar* functions instead of the previous push/pop functions. These acet-sysvar* functions are built-in functions in BricsCAD.
My application must be compatible with AutoCAD 2011 and higher, and also with BricsCAD V14 and higher.
If I remember correctly the functions "acet-sysvar*" is inserted in the Express Tools in AutoCAD, so in theory if the user has not installed Express Tools your solution does not work in AutoCAD: right?
Is there some way to make it work even in AutoCAD without Express Tools?
roy_043
  • BricsCAD 18
« Reply #11 on: July 21, 2016, 04:46:15 PM »
I have edited post #8.
Lupo76
« Reply #12 on: July 22, 2016, 08:57:21 AM »
Hello Roy,
with your help I solved the problem.
However I have not used functions "KGA_Sys_VarStackPush" and "KGA_Sys_VarStackPop".
Why did you have entered these functions?
I see no reason to use them.
roy_043
  • BricsCAD 18
« Reply #13 on: July 22, 2016, 09:21:55 AM »
I am glad to hear that.
To avoid highlighting and gripping the 'sssetfirst' selection set. You may not notice any effect on small sets (although in BricsCAD I do detect an extra 'blink') but even then this will have an impact on speed.
Lupo76
« Reply #14 on: July 22, 2016, 10:35:26 AM »
You're right!
now I understand what you did!
Thank you.
