Hello to all,
I hope to be able to explain my problem.
I inserted an object reactor that intervenes every time I move an object.
But by performing the following steps I have a problem:
- Start the MOVE command and pick any object and conclude the movement
- Then start again the MOVE command (or COPY / MIRROR) and when prompted to select the objects I type "p" to select the object of the first step.
Unfortunately, the selection group of the second step, contains unwanted objects definitely coming from the reactor processing.
I have noticed that this happens because I used inside the reactor (ssget "X" ......)
How can I avoid this?
I thought I'd save in a variable the selection of the first step group and restore it in the "previous selection set" (the option "P"); but I need your help to do this.
Thanks in advance.
