Author Topic: Problem with the previous selection set  (Read 5256 times)
Lupo76
Re: Problem with the previous selection set
« Reply #15 on: July 24, 2016, 11:19:46 AM »
with your help I solved the problem.
I am glad to hear that.
However I have not used functions "KGA_Sys_VarStackPush" and "KGA_Sys_VarStackPop".
Why did you have entered these functions?
To avoid highlighting and gripping the 'sssetfirst' selection set. You may not notice any effect on small sets (although in BricsCAD I do detect an extra 'blink') but even then this will have an impact on speed.
Instead of using your functions KGA ... I preferred to use (setvar "GRIPS" 0).
Unfortunately, the error appears:
the AutoCAD variable properly rejected: "GRIPS" 0;
This happens why it is inserted into a reactor?
roy_043
  • BricsCAD 18
« Reply #16 on: July 25, 2016, 05:55:55 AM »
Are you saying this error does not occur when KGA_Sys_VarStackPush/Pop are being used?
If so try using:
(setvar 'GRIPS 0)
Lupo76
« Reply #17 on: July 25, 2016, 06:13:43 AM »
If so try using:
(setvar 'GRIPS 0)
No, I have not tried KG _.... because in my context was more readable (for me) my solution.
Unfortunately also
(setvar 'GRIPS 0) does not work  :cry:
roy_043
  • BricsCAD 18
« Reply #18 on: July 26, 2016, 04:34:38 AM »
I do not have an AutoCAD license and therefore cannot help you with this issue. But IMO it is another reason to abandon the ssget 'workaround' and use Xdata to store the group.
Lupo76
« Reply #19 on: July 26, 2016, 06:28:24 AM »
You are right, but change my approach is not simple, requires much work and extensive testing, and at this moment I do not have time to do this.
I must find a way to preserve the selection set before the start of reactor.
Lupo76
« Reply #20 on: July 31, 2016, 09:54:17 AM »
Today, finally I had a little time to try again.
I realized that I had made a typing error on the name of the variable HIGHLIGHT,
Now your trick works properly.
Thank you.
