Author Topic: Block with annotative and non-annotative objects  (Read 1906 times)
Jeff H
« on: July 20, 2016, 12:14:07 PM »
Seems like I've seen this asked and someone just asked me about this, and can't remember seeing an answer so sorry if missed it, but someone was wanting one for motion sensor where the coverage was non-annotative.
Seems to work if you nest an annotative block inside another non-annotative block with entities that are non-annotative, you just have make sure you add more than one annotative scale inside the block editor to the nested annotative block.
Attached is an example where square is non-annotative and circle is nested annotative block.
ChrisCarlson
Re: Block with annotative and non-annotative objects
« Reply #1 on: July 20, 2016, 12:55:15 PM »
The same can be applied to annotative text and attrib within a non-annotative block. However I do not think you can have non-annotative objects within an annotative block.
