Author Topic: PDF measures incorrectly over viewport  (Read 3136 times)
alanjt
  • Standby for witty remark...
« on: July 12, 2016, 11:38:06 AM »
I had a user email me a PDF yesterday that has some kind of scaling oddity.
If you print the PDF, everythying scales correctly, however, if you use the measure tool in Acrobat, it doesn't measure correctly. I even noticed that if I place the graphic scale (in paperspace) atop the viewport, it doesn't scale properly either, but away from the viewport scales as it should.
Thoughts?
Dropbox
Re: PDF measures incorrectly over viewport
« Reply #1 on: July 12, 2016, 11:57:47 AM »
how are you printing?
Actual Size
Scale to fit
etc...
the issue may be incorrect 'paper' size in the page setup they used, and or they plotted to window/fit to paper...or some other randomness
the resultant PDF wont tell us much, the source drawing/plotting method is where the issue originates.
alanjt
« Reply #2 on: July 12, 2016, 12:02:09 PM »
Actual Size
Scale to fit
etc...
Scale: 1" = 1'
Plot area set to extents and Layout and neither work.
All is correct. I even created a new layout and viewport in the drawing and it still creates the strange PDF.
Thing is, if you print the PDF to paper, it scales correctly.
Dropbox
« Reply #3 on: July 12, 2016, 12:10:28 PM »
what do you mean by this
As in the page setup doesn't yield a good plot preview, or expected output?o
OR
the pdf still scales wrong when inserted back into autocad?
Suggest you strip identifying data and let us see the drawing or some form thereof
« Reply #4 on: July 12, 2016, 12:22:53 PM »
notice this...
when inserting your wacky pdf into a black file on a layout tab...
Enter page number or [?] <1>:
Specify insertion point: 0,0,0
Base image size: Width: 36.0029, Height: 24.0019, Feet
appears to go back to correct page size defined when printed...because my brain says that paper is supposed to be 36x24 with no extra digits
MSTG007
« Reply #5 on: July 12, 2016, 12:54:43 PM »
same here....
Specify scale factor or [Unit] <1>: *Cancel*
Civil3D 2020
ChrisCarlson
« Reply #6 on: July 12, 2016, 01:33:26 PM »
Seems to be an Adobe bug, the two scales are correct in BlueBeam.
ChrisCarlson
« Reply #7 on: July 12, 2016, 01:34:18 PM »
Snippet attached
steve.carson
« Reply #8 on: July 12, 2016, 01:55:03 PM »
You've probably already done this, but have you verified the VPort scale is correct in the DWG?
It seems the embedded scale ratio is off in the PDF. Obviously it should be 10, but it's 7.07. It's possible to turn it off in Adobe by starting the Measuring Tool, then right clicking the drawing area and selecting Preferences and unckecking the box under "Measuring (2D)" at the top that says "Use Scale and Units from Document (when present)". Then you can manually set the Scale ratio to 10 by right clicking the drawing area again and selecting "Change Scale Ratio".
HTH
Steve
alanjt
« Reply #9 on: July 13, 2016, 10:03:10 AM »
It has to be something in the file.
Let me see if I can hack out enough and post the DWG.
Dropbox
