Author Topic: Insert breakline  (Read 2685 times)
cadtag
Insert breakline
« on: July 01, 2016, 10:20:56 AM »
Here's one question that's been puzzling me....  In Prospector, Suface Defintion, expanding Breaklines, and then right-clicking on a breakline set name,  one of the options is 'Insert Breaklines to Drawing'.  WTF is that supposed to do?  If the breaklines have been erased from the drawing with the surface, then the surface is out of date and has to be rebuilt.
All I've ever gotten if I try that oiption, is a notice that No Breaklines were inserted.  So just waht is that supposed to do, and when should/can it be used?
The only thing more dangerous to the liberty of a free people than big government is big business
Re: Insert breakline
« Reply #1 on: July 01, 2016, 10:59:29 AM »
That particular function never has functioned.
However what it is or what it was supposed to do dates back to land desktop.
In that setting, the surfaces were not dynamic, however if one needed to alter a breakline, one could first
insert the breakline to the drawing, then delete the breakline from the surface. Edit the previously inserted breakline elevations or slope;
and then add it back into the surface.
There are timesi, once just last week, that it sure would be nice IF that tool did work.  However I doubt it will ever be fixed so that it does work.
This
, is not entirely true if one has the setting
"Copy deleted dependant objects" turn on.
cadtag
« Reply #2 on: July 01, 2016, 12:11:09 PM »
OK, that makes typical C3D sense , bring over an option from LDT, but never actually implement it.
Of interest is that the breakline properties are still in the drawing surface definition, even though the breaklines themselves are not.  I suppose I _could_ re-enter them.. all 1,542 breaklines with 71,797 vertices.
Description   Easting (X)   Northing (Y)   Elevation (Z)
Breakline set6:1
1   938051.8879   531076.1537   8.15
2   938051.7697   531077.1848   8.07
3   938048.8988   531077.5208   7.88
4   938046.0278   531077.8569   7.69
5   938044.2916   531077.6866   7.59
6   938042.1046   531076.9037   7.53
7   938041.8278   531076.0665   7.55
8   938042.4971   531075.5069   7.62
« Reply #3 on: July 01, 2016, 12:16:20 PM »
OK, that makes typical AUTODESK logic , bring over an option from LDT, but never actually implement it.
Breakline set6:1
ftfy
Actually one could get them from the surface.xml file after exporting the surface to landXML  just look for the breakline section...and script them in.
ETA
Or edit the xml file severely and see if it would bring in only the breaklines, I've not tried that.  However I have edit the xml to get the point data from a few surfaces.
« Last Edit: July 01, 2016, 12:23:52 PM by mjfarrell »
DanB
« Reply #4 on: July 25, 2016, 04:54:40 PM »
<removed>
