Author Topic: Open AutoCAD from batch file  (Read 1183 times)
dudi_dk
« on: June 29, 2016, 06:22:33 AM »
Hello,
I need to start AutoCAD from a Batch file.
I need to be able to start few AutoCAD sessions from a batch file.
I need to be able to add a "/b" (For running a script on the opened file) to the AutoCAD "Calling" in the batch file.
If I use …
START "C:\Program Files\Autodesk\AutoCAD 2015\acad.exe" "C:\Users\dudik\Desktop\111.dwg" "/nologo"
Then the AutoCAD does not read the /nologo
If I use …
Then I can not add another session of AutoCAD (in order to have two AutoCAD sessions open)
Thanks in advance,
David
Crank
Re: Open AutoCAD from batch file
« Reply #1 on: July 06, 2016, 12:47:05 PM »
If you want speed, then don't use acad.exe. Consider using the Core Console.
« Last Edit: July 06, 2016, 12:51:05 PM by Crank »
