Author Topic: Rotating Text in an MLeader  (Read 1646 times)
Atook
  • AKA Tim
« on: June 28, 2016, 01:48:13 PM »
I'm trying to rotate text in an MLeader, but ending up with weird results.
For some/most labels it works, but sometimes the text conflicts with the leaderline. If I double click on the endpoint of the leader, the text corrects it's self to the correct side (wanted.png)
Here's the code I'm using:
Code - C#: [Select]
  1. private static void SetLabelRotation(IEnumerable<ObjectId> labelIds, LockedTransaction acTr, double rotation)
  2. {
  3.         foreach (ObjectId id in labelIds)
  4.         {
  5.                 Entity ent = acTr.GetObject(id, OpenMode.ForWrite, false) as Entity;
  6.                 MLeader pipeLabel = ent as MLeader;
  7.                 if (pipeLabel != null)
  8.                 {
  9.                         // clone the old text and replace it
  10.                         MText oldText = pipeLabel.MText;
  11.                         MText newText = oldText.Clone() as MText;
  12.                         if (newText != null)
  13.                         {
  14.                                 // set the rotation
  15.                                 newText.Rotation = rotation;
  16.                                 pipeLabel.MText = newText;
  17.                                 // try resetting attachments? this doesn't work
  18.                                 newText.Attachment = AttachmentPoint.MiddleCenter;
  19.                                 pipeLabel.TextAttachmentType = TextAttachmentType.AttachmentMiddle;
  20.                         }
  21.                 }
  22.         }
  23. }
I could just recreate the mleader, but I'd really like to keep the same one because I write it's handle to the polyline it's describing. Any ideas?
« Last Edit: June 28, 2016, 02:16:10 PM by Atook »
MickD
Re: Rotating Text in an MLeader
« Reply #1 on: June 28, 2016, 09:04:26 PM »
sometimes I've found that you need to add the new MText object to the db before fine tuning the properties and making them stick.
hth
- John Carmack
- J.R.R. Tolkien
