Author Topic: Scale By Selecting Text Height  (Read 1331 times)
MSTG007
« on: June 28, 2016, 07:57:01 AM »
If you have two blocks at different scales, and you want to match the text height of one to the other. How can you do that?
Civil3D 2020
Re: Scale By Selecting Text Height
« Reply #1 on: June 28, 2016, 08:00:46 AM »
Determine text height from block definition of target block and multiply by target block scale; divide result by text height within block definition of block to be modified; set block scale to result.
MSTG007
« Reply #2 on: June 28, 2016, 08:03:24 AM »
Yup, I get that one. I just did not know if there was a routine that I could select a text height in one block and one in another block. then the second block scales the whole block to the first block? Does that make sense?
Civil3D 2020
ChrisCarlson
« Reply #3 on: June 28, 2016, 08:06:52 AM »
Its relatively easy, provided neither block is annotative.
roy_043
  • BricsCAD 18
« Reply #4 on: June 28, 2016, 08:09:54 AM »
I think you are looking for (nentsel).
MSTG007
« Reply #5 on: June 28, 2016, 05:49:17 PM »
I have been toying around on this today. Is it possible to have a user select a line length within a block and then use that as a reference to scale up another block?
I have been trying to setup a macro to do this, I just cant figure it out.
So the user would have two blocks (Could be the same at different scales or 2 total different blocks)
User would select a line entity within block 1 (which would grab the length)
It would prompt user to select target block 2 entity.
User would select a line that is not the same length as block 1.
Routine would then compare the lengths and scale block 2 to match the same length of the line that was initially selected.
I was trying a script but that blew up! lol.
Thanks for any help on this guys.
Civil3D 2020
