Hello guys !
I try to understand this very useful code from
http://through-the-interface.typepad.com/through_the_interface/2007/10/allowing-select.htmlBut I didnīt why I get exception after runnig (see picture).
What I have done before is:
Command: MPLOT
1 None
2 Snagit 12
3 Send To OneNote 2013
4 PDFCreator
5 PDF Report Writer
6 Microsoft XPS Document Writer
7 Fax
8 CutePDF Writer
21 DWG To PDF.pc3
22 DWGToDWF_HANNA.pc3
23 DWGToPDF_HANNA.pc3
24 DWGToPLT_HANNA.pc3
25 Pdf.pc3
26 PDFCreator.pc3
Enter number of device to select: 21
Selected: DWG To PDF.pc3
1 ISO_full_bleed_B5_(250.00_x_176.00_MM)
2 ISO_full_bleed_B5_(176.00_x_250.00_MM)
3 ISO_full_bleed_B4_(353.00_x_250.00_MM)
4 ISO_full_bleed_B4_(250.00_x_353.00_MM)
5 ISO_full_bleed_B3_(500.00_x_353.00_MM)
45 ANSI_full_bleed_A_(8.50_x_11.00_Inches)
46 ISO_expand_A0_(841.00_x_1189.00_MM)
47 ISO_A0_(841.00_x_1189.00_MM)
48 ISO_expand_A1_(841.00_x_594.00_MM)
49 ISO_expand_A1_(594.00_x_841.00_MM)
50 ISO_A1_(841.00_x_594.00_MM)
51 ISO_A1_(594.00_x_841.00_MM)
52 ISO_expand_A2_(594.00_x_420.00_MM)
Enter number of media to select: 51
Selected: ISO_A1_(594.00_x_841.00_MM)
Regenerating layout.
Have somebody a idea or what I do wrong?!
