someone can help me with a lisp that can evenly distribute blocks. attached an image where the value of "x" must be equal. the idea is that you can change at any time the value of "x" so they can see more or less adjusted according to whatever you want.
Deputy dwg.
PDTA: research found a lisp teacher Lee Mac, but when you run the lisp then have to update the attributes of each block to return to his position; also they are not exactly the same distance.
associate the lisp "eqsp" - "Lee Mac".
