Author Topic: Quadrants  (Read 5521 times)
nobody
  • .net stuff
Quadrants
« on: June 20, 2016, 10:31:11 PM »
I need to write code to determine the two quadrants for two lines at different bearings....but can't wrap my head around how many cases will be possible so I can be sure I'm accounting for them all... anyone know this already?
quadrant being north, south, east, west
see attached image, and thanks!
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: Quadrants
« Reply #1 on: June 20, 2016, 10:59:58 PM »
Could both vectors point into the same quadrant in your world ??
ie: 1 o'clock and 2 o'clock etc ?
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
Re: Quadrants
« Reply #2 on: June 20, 2016, 11:07:10 PM »
Ignoring the order the vectors are considered in :
I believe the short answer is 10
Opposite Quadrant : 2 options
Adjacent Quadrant   : 4 options
Same Quadrant     : 4 options
added:
and ignoring the Cardinal directions.
« Last Edit: June 20, 2016, 11:10:35 PM by kdub »
nobody
  • .net stuff
Re: Quadrants
« Reply #3 on: June 21, 2016, 01:29:06 AM »
crud they can :/
nobody
  • .net stuff
Re: Quadrants
« Reply #4 on: June 21, 2016, 01:51:14 AM »
added:
oy... good point with the cardinal directions :/  this is going to be harder than anticipated
kdub_nz
  • SuperMod
Re: Quadrants
« Reply #5 on: June 21, 2016, 02:14:53 AM »
I'm more than just a pretty face with a questionable sense of humour :)
roy_043
  • BricsCAD 18
Re: Quadrants
« Reply #6 on: June 25, 2016, 08:57:10 AM »
If the quadrants are north, east, south and west I would argue that 1 o'clock and 2 o'clock are not in the same quadrant.
« Last Edit: June 25, 2016, 09:12:55 AM by roy_043 »
kdub_nz
  • SuperMod
Re: Quadrants
« Reply #7 on: June 25, 2016, 09:46:34 AM »
whatever,
but I'd wager that's not the case.
If you look at his piccy the Cardinal directions appear to be at 12, 3, 6, 9 ... but I've been wrong before :)
and the proposition about 2 vectors in the same quadrant holds.
nobody
  • .net stuff
Re: Quadrants
« Reply #8 on: June 25, 2016, 11:06:30 PM »
whatever,
Correct...12,3,6,9.... but thanks all, I'm abandoning the cause... there are far too many conditions to account for.... not worth the effort. Not only can the vectors be opposite, vertical / horizontal, but acute angles and both vectors heading toward the same quadrant....I'll need to try and figure out a different way to address the problem :/
kdub_nz
  • SuperMod
Re: Quadrants
« Reply #9 on: June 25, 2016, 11:27:00 PM »
Finally, we come to the issue :
What is the problem ?
The Conditionals are known.
The Vectors are calculatable.
Seems to me the issue is lexical (naming the unique conditions ) rather than mathematical or logical.
roy_043
  • BricsCAD 18
Re: Quadrants
« Reply #10 on: June 26, 2016, 07:43:37 AM »
... The issue is indeed about definitions. IMO the north sector is bisected by the north direction. So assuming 12 o'clock is north, 1 and 2 o'clock are not in the same sector.
NW > north sector >= NE
nobody
  • .net stuff
Re: Quadrants
« Reply #11 on: June 26, 2016, 01:11:10 PM »
I'm not sure I have all the possible scenario's accounted for graphically...which makes it that much more difficult to do it programmatically... :/
« Last Edit: June 26, 2016, 01:22:31 PM by Area51Visitor »
roy_043
  • BricsCAD 18
Re: Quadrants
« Reply #12 on: June 28, 2016, 04:20:28 AM »
If you limit the orientation of the lines to N, NE, E etc., consider N+NE to be equal to NE+N etc., and include the cases where the lines are superimposed, there a [8*8]/2 = 32 combinations.
MickD
Re: Quadrants
« Reply #13 on: June 28, 2016, 09:00:39 PM »
Can't you use the angle of the lines in radians to determine quadrant? or am I missing something? (probably :) )
eg. 0 -> pi/2 is quadrant from 12 o'clock to 3 o'clock, pi/2 -> pi = 9-12 o'clock, pi -> 3pi/2 = 9-6 o'clock and 3pi/2 -> 2pi = 6-3 o'clock.
obviously you will need to rationalise what happens at 3, 6, 9 and 12 o'clock positions.
- John Carmack
- J.R.R. Tolkien
kdub_nz
  • SuperMod
Re: Quadrants
« Reply #14 on: June 29, 2016, 11:19:18 PM »
Try this :
Note: Check the Bit values for veracity ... I rushed this a little
« Last Edit: June 29, 2016, 11:25:35 PM by kdub »
