Author Topic: NCOPY slow?  (Read 3132 times)
MSTG007
NCOPY slow?
« on: June 20, 2016, 10:56:28 AM »
Just getting some basic feedback. Why is the NCOPY command slow? Is there a faster routine that can do somewhat of the same thing?
Civil3D 2020
Rob...
Re: NCOPY slow?
« Reply #1 on: June 20, 2016, 11:01:36 AM »
I see no lag in it here. Tried with a block and an XREF.
CAD Tech
MSTG007
Re: NCOPY slow?
« Reply #2 on: June 20, 2016, 11:04:15 AM »
Wow I have tried it on several other machines here and there is still a 2 second lag time (where its trying to find the object.)
Civil3D 2020
Rob...
Re: NCOPY slow?
« Reply #3 on: June 20, 2016, 11:08:00 AM »
Is it slower with larger files than smaller ones?
What are you copying (types of objects, how many, etc.) and from where (block, XREF (local or network))?
CAD Tech
Re: NCOPY slow?
« Reply #4 on: June 20, 2016, 11:09:40 AM »
what setting is INDEXCTL in your XREF'ed files?
MSTG007
Re: NCOPY slow?
« Reply #5 on: June 20, 2016, 11:10:08 AM »
INDEXCTL is set to 3
Civil3D 2020
Re: NCOPY slow?
« Reply #6 on: June 20, 2016, 11:24:43 AM »
and are your demand loading with copy your xrefs?
MSTG007
Re: NCOPY slow?
« Reply #7 on: June 20, 2016, 11:32:50 AM »
Demand Load Xrefs:
Enabled with Copy
Checked = Retain Changes to Xref layers
Checked = Allow other users to Refedit current drawing
Civil3D 2020
Rob...
Re: NCOPY slow?
« Reply #8 on: June 20, 2016, 11:34:29 AM »
What are you copying (types of objects, how many, etc.) and from where (local or network))?
Still wondering.
CAD Tech
MSTG007
Re: NCOPY slow?
« Reply #9 on: June 20, 2016, 11:39:28 AM »
We are using Civil3D 2016. The Xref base files are survey drawings that are 2D (no 3d objects) and your improvement site drawing, that has no 3D Data in it. We are on a 1,000MB LAN, and the drawings are around 2 to 5 MB. Now I have not tried it with vanilla autocad or Civil3d as AutoCAD.
Civil3D 2020
Re: NCOPY slow?
« Reply #10 on: June 20, 2016, 11:48:56 AM »
certain you have already done this, yet...
try audit/recover on one or two of the slow files, and see if performance improves.
As it is standard 2d linework for sure nothing civil 3d, no feature lines or survey figures,
one could substitute a MAP query to get your hands on those objects.  (IF they are actual Civil 3d objects FORGET about using query because it (MAP) wont touch them)
huiz
  • Certified Prof C3D
Re: NCOPY slow?
« Reply #11 on: June 20, 2016, 01:15:12 PM »
It might be the setting for Dynamic UCS. If you have a huge Xref there is a lag when you start a command. But I am not sure if this happens in select mode, I am sure it is in draw mode.
Turn it off to see the difference.
