Author Topic: POWER BBPOLY FROM LEE MAC?!China Version  (Read 2234 times)
meja
« on: June 20, 2016, 09:17:22 AM »
I have see this post
http://www.cadtutor.net/forum/showthread.php?81662-Max-X-and-minus-x&s=5ece95b75014b7e09e3d41e7bf032fd1
I use lisp for longlong time
A few days ago I GET one gi like this
This tool support line arc pline and      SPLINE!!!
meja
Re: POWER BBPOLY FROM LEE MAC?!China Version
« Reply #1 on: June 25, 2016, 09:15:40 AM »
;; Batch BPoly  -  Lee Mac
;; Generates polylines for every region formed by a selection of lines & polylines
;; Restricted to LWPolylines with linear segments only.
;; Region generation based on a method by Stefan M.
(defun c:bbpoly ( / *error* big ent enx idx int lst pt1 pt2 rtn sel spc tmp tot val var vtx )
    (defun *error* ( msg )
        (foreach obj rtn
            (if (and (vlax-write-enabled-p obj) (not (vlax-erased-p obj)))
                (vla-delete obj)
        (mapcar 'setvar var val)
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
    (LM:startundo (LM:acdoc))
        (   (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (getvar 'clayer))))))
            (princ "\nCurrent layer locked.")
        (   (setq sel
                (LM:ssget "\nSelect Lines & Polylines: "
                    (list
                        (list
                           '(-4 . "<OR")
                               '(0 . "LINE")
                               '(-4 . "<AND")
                                   '(0 . "LWPOLYLINE")
                                   '(-4 . "<NOT")
                                       '(-4 . "<>")
                                       '(42 . 0.0)
                                   '(-4 . "NOT>")
                               '(-4 . "AND>")
                           '(-4 . "OR>")
                            (if (= 1 (getvar 'cvport))
                                (cons 410 (getvar 'ctab))
                               '(410 . "Model")
            (setq spc
                (vlax-get-property (LM:acdoc)
                        'paperspace
                        'modelspace
            (repeat (setq idx (sslength sel))
                (if (= "LINE" (cdr (assoc 0 (setq enx (entget (ssname sel (setq idx (1- idx))))))))
                    (setq lst (cons (list (cdr (assoc 10 enx)) (cdr (assoc 11 enx))) lst))
                    (setq vtx (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (= 10 (car x))) enx))
                          vtx (mapcar 'list vtx (if (= 1 (logand 1 (cdr (assoc 70 enx)))) (cons (last vtx) vtx) (cdr vtx)))
                          lst (append vtx lst)
            (foreach pl1 lst
                (setq pt1 (car  pl1)
                      pt2 (cadr pl1)
                (foreach pl2 lst
                        (and
                            (not (equal pl1 pl2 1e-8))
                            (setq int (inters pt1 pt2 (car pl2) (cadr pl2)))
                            (not (vl-member-if '(lambda ( pnt ) (equal pnt int 1e-8)) pl1))
                        (setq pl1 (cons int pl1))
                (setq rtn
                    (append
                        (mapcar
                            (function
                                (lambda ( a b )
                                    (vla-addline spc
                                        (vlax-3D-point a)
                                        (vlax-3D-point b)
                            (setq pl1
                                (vl-sort pl1
                                    (function
                                        (lambda ( a b )
                                            (< (distance pt1 a) (distance pt1 b))
                            (cdr pl1)
                        rtn
            (setq var '(cmdecho peditaccept)
                  val  (mapcar 'getvar var)
                  tot  0.0
            (mapcar 'setvar var '(0 1))
            (foreach reg (vlax-invoke spc 'addregion rtn)
                (setq ent (entlast))
                (command "_.pedit" "_m")
                (apply 'command (mapcar 'vlax-vla-object->ename (vlax-invoke reg 'explode)))
                (command "" "_j" "" "")
                    (and
                        (not (eq ent (setq ent (entlast))))
                        (= "LWPOLYLINE" (cdr (assoc 0 (entget ent))))
                        (setq tmp (vlax-curve-getarea ent)
                              tot (+ tot tmp)
                        (if (< (car big) tmp)
                            (setq big (list tmp ent))
                (vla-delete reg)
            (if (equal (car big) (/ tot 2.0) 1e-3) ;; Gian Paolo Cattaneo
                (entdel (cadr big))
            (foreach obj rtn (vla-delete obj))
;; ssget  -  Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; msg - [str] selection prompt
;; arg - [lst] list of ssget arguments
(defun LM:ssget ( msg arg / sel )
    (princ msg)
    (setvar 'nomutt 1)
    (setq sel (vl-catch-all-apply 'ssget arg))
    (setvar 'nomutt 0)
    (if (not (vl-catch-all-error-p sel)) sel)
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
)(vl-load-com) (princ)
ribarm
  • Marko Ribar, architect
« Reply #2 on: June 25, 2016, 11:06:18 AM »
Although I have created my lisp that can do this with all curve types, this plugin isn't free - see for yourself this version that operates only on lines, arcs, circles and polylines and yet still it has its prize :
http://www.delicad.com/en/flashpolygons.php
What do you expect to post this code for free? I am out...
M.R. on Youtube
meja
« Reply #3 on: June 26, 2016, 05:41:31 AM »
HI,BUD
your lisp cannot support spline!!!Iust same like bbpoly,but it is free!
ribarm
« Reply #4 on: June 26, 2016, 07:43:18 AM »
My lisp can support SPLINES and other curve types and I am not posting it...
M.R. on Youtube
