I studied a little 'code (vlax-put obj 'coordinates ...)
However there is much work to do to achieve the result as if, for example, a multi-line has 4 vertices I find 8 point coordinates and then I am forced to find the 2 vertex coordinates perpendicular to each other.
I should be able to do this but there is much work to do.
Before doing this I would like to dedicate some of my time to see if there is something ready
