Author Topic: Civil 3d View Frame (or rectangular polyline)  (Read 2713 times)
nobody
  • .net stuff
« on: June 18, 2016, 11:38:02 PM »
How can I get the angle of a rectangular polyline along the longer line?
« Last Edit: June 18, 2016, 11:41:07 PM by Area51Visitor »
nobody
  • .net stuff
Re: Civil 3d View Frame (or rectangular polyline)
« Reply #1 on: June 19, 2016, 12:06:26 AM »
Nevermind peeps...just use Math.Max(Math.Max(Math.Max))) to get the longer segment.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #2 on: June 19, 2016, 12:24:16 AM »
What are you applying the Math.Max to ??
I don't use Civil3D and I didn't notice a Rectangle Class that has the side lengths as properties.
Called Kerry in my other life
I live at UTC + 13.00
nobody
  • .net stuff
« Reply #3 on: June 19, 2016, 02:17:20 PM »
Was for the line segment with the longer length.  Exploded the polyline down to line segments to get their lengths and used the example here: http://stackoverflow.com/questions/6800838/in-c-sharp-is-there-a-method-to-find-the-max-of-3-numbers
The longer line I used as my objectId to get the angle I wanted
Bryco
« Reply #4 on: June 20, 2016, 09:28:53 AM »
I cycle through the points finding the longest length, then use the angle property of the vector of those 2 pts. Gets a little trickier w/ 3d
nobody
  • .net stuff
« Reply #5 on: June 20, 2016, 10:07:30 PM »
ha...ya... I was being pretty lazy.
Line.Angle lol
kdub_nz
  • SuperMod
« Reply #6 on: June 20, 2016, 11:28:18 PM »
Some people would check if it is actually a rectangle :
4 sides,
4 corners, diagonals equal ....
sidetrack :
does the Line.Angle return the angle relative to WCS UCS ECS DCS PSDCS ??
nobody
  • .net stuff
« Reply #7 on: June 21, 2016, 01:32:57 AM »
4 sides,
sidetrack :
good point... I'm not considering anything in regards to wcs/ucs, etc... I'll need to verify it wont mess anything up. Thanks!
