Author Topic: Get an attribute value to dwgprops  (Read 1320 times)
MeasureUp
« on: June 15, 2016, 02:07:10 AM »
By reading couple of posts, here is a code which I used for passing an attribute value from a block to "dwgprops".
But it doesn't look right.
What is wrong in the code? Thanks for your help.
(defun c:Test ()
(defun get_att (en / att obj)
(if (or (and (eq (type en) 'ENAME)
             (setq obj (vlax-ename->vla-object en))
             (eq (vla-get-hasattributes obj) :vlax-true)
        (and (eq (type en) 'VLA-OBJECT)
             (setq obj en)
    (mapcar
      '(lambda (att) (cons (vla-get-TagString att) (vla-get-TextString att)))
      (vlax-invoke obj "GetAttributes")
(if (setq ss (ssget "_:S:E" '((0 . "INSERT") (2 . "BlockName")))) ; <= change "BlockName" to yours for testing
(progn (setq obj (vlax-ename->vla-object (ssname ss 0)))
   (if (eq (vla-get-effectivename obj) "BlockName") ; <= change "BlockName" to yours for testing
   (progn (get_att obj)
  (setq DwgCustomProperties (car (car (get_att obj)))) ; <= 1st attribute in the selected block
  (setq DwgCustomDescription (cdr (car (get_att obj))))
    (princ "\nSelect a block...")
(setq summaryinfo (vla-get-SummaryInfo (vla-get-ActiveDocument (vlax-get-acad-object))))
(vla-SetCustomByKey summaryinfo DwgCustomProperties DwgCustomDescription)
); end
Re: Get an attribute value to dwgprops
« Reply #1 on: June 15, 2016, 03:28:41 AM »
The setcustombykey method assumes that the custom property corresponding to the supplied key already exists; if it doesn't, you will first need to use the addcustominfo method to create it.
MeasureUp
« Reply #2 on: June 15, 2016, 09:27:22 PM »
Thanks Lee. It is informative.
But the following code seems to erase all existing keys in "dwgprops". How to avoid this?
(if (>= (vla-NumCustomInfo summaryInfo) 1)
(vla-SetCustomByIndex summaryInfo 0 CustomPropertyBranch PropertyBranchValue)
(vla-AddCustomInfo summaryInfo CustomPropertyBranch PropertyBranchValue)
roy_043
  • BricsCAD 18
« Reply #3 on: June 16, 2016, 03:02:39 AM »
You should look at the order of the 'then' and 'else' expressions. Reverse them (or change the test expression). Or better still just use:
MeasureUp
« Reply #4 on: June 20, 2016, 02:14:10 AM »
Thanks for your tip. My code is now running perfectly.
