If you're talking about the Autodesk.AutoCAD.DatabaseServices.Arc type (IOW Arc entity) it's always counterclockwise according to is Normal.
If you are talking about a Polyline arc segment, you have to check the Bulge sign (negative = clockwise).
Only the Autodesk.AutoCAD.Geometry.CircularArc2d type have a IsClockWise property.
