Author Topic: -={ Challenge }=- 24 point games or Math24  (Read 2636 times)
qjchen
  • Best wishes to all
« on: June 10, 2016, 11:51:17 PM »
https://en.wikipedia.org/wiki/Maths24#Combinations
I often play this game by cards game. That means use + - * / and  ( ) to calculate four card's number into 24. Just like
For 2,5,5,7=>((2x7)+5)+5
For 5,5,6,6=>((5+5)-6)x6
The rules is Given four number (In a poker game, it can be four cards, A stand for one, 2,3,4,5,6,7,8,9,10 for each number, and J for 11, Q for 12, K for 13), and then Cards are solved by using the numbers, applying only the addition, subtraction, multiplication and division operations to achieve a final mathematical solution of 24.
All four numbers must be included. The numbers can only be used once. No other mathematical operations are allowed.
Yesterday, I wrote some codes to finish it. But I think there are so many clever Lispers in theswamp, so now I post it here and I hope there are many better codes appear.
The challenge:
(defun c:test (/ lst)
  (setq   lst  (list a b c d))
(princ the solution)
where a b c d can be any int number or they can be limited to cards game (from 1 to 13).
The results can be duplicate. just like this:
Command: test
a:2
b:3
c:4
d:5
((* (- 5.0 (- 2.0 3.0)) 4.0) . 24.0)
((* (+ (- 3.0 2.0) 5.0) 4.0) . 24.0)
« Last Edit: June 11, 2016, 08:21:32 AM by qjchen »
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
new_mem
Re: -={ Challenge }=- 24 point games or Math24
« Reply #1 on: June 11, 2016, 04:24:44 AM »
Maybe
(setq a (getreal "\n Select a: "))
  (setq b (getreal "\n Select b: "))
  (setq c (getreal "\n Select c: "))
  (setq d (getreal "\n Select d: "))
^_^
snownut2
  • Bricscad 22 Ultimate
« Reply #2 on: June 11, 2016, 07:20:35 AM »
Maybe
^_^
I'm thinking it needs to be 4 randomly choosen (by computer) cards out of a deck of playing cards, whose options are constantly changing to cards already delt...
qjchen
« Reply #3 on: June 11, 2016, 07:43:23 AM »
Maybe
^_^
Thank you new_mem and snownut2 for reply. Your suggestions is very good. It is better to use user input or computer random input.
But maybe at the first step, just now only solution is need, and I think it is not too hard to improve it to a good Lisp game :)
new_mem
« Reply #4 on: June 11, 2016, 08:08:16 AM »
Sorry i don't understand the rule  math24 .
Can u tell me ?
qjchen
« Reply #5 on: June 11, 2016, 08:20:36 AM »
Can u tell me ?
The rules is like so: Given four number (In a poker game, it can be four cards, A stand for one, 2,3,4,5,6,7,8,9,10 for each number, and J for 11, Q for 12, K for 13), and then Cards are solved by using the numbers, applying only the addition, subtraction, multiplication and division operations to achieve a final mathematical solution of 24.
It is illustrated more carefully in https://en.wikipedia.org/wiki/Maths24#Rules.
Thank you for your participation.
« Reply #6 on: June 11, 2016, 10:50:36 AM »
A basic brute-force method:
  1. (defun LM:math24 ( a b c d )
  2.     (vl-remove-if-not '(lambda ( x ) (equal 24.0 (eval x) 1e-8))
  3.         (apply 'append
  4.             (mapcar
  5.                '(lambda ( a )
  6.                     (mapcar '(lambda ( b ) (-formulate- b (car a) (cdr a))) (-operators-))
  7.                 )
  8.                 (   (lambda ( npr ) (npr (mapcar 'float (list a b c d)) 4))
  9.                     (lambda ( l r )
  10.                         (if (< r 2)
  11.                             (mapcar 'list l)
  12.                             (apply 'append (mapcar '(lambda ( a ) (mapcar '(lambda ( b ) (cons a b)) (npr (-remove1st- a l) (1- r)))) l))
  13.                         )
  14.                     )
  15.                 )
  16.             )
  17.         )
  18.     )
  19. )
  20.
  21. (defun -formulate- ( o x l )
  22.     (if (and o l) (-formulate- (cdr o) (list (car o) x (car l)) (cdr l)) x)
  23. )
  24.
  25. (defun -remove1st- ( x l )
  26.     (cond
  27.         (   (not l) nil)
  28.         (   (equal x (car l)) (cdr l))
  29.         (   (cons (car l) (-remove1st- x (cdr l))))
  30.     )
  31. )
  32.
  33. (defun -operators- nil
  34.     (eval
  35.         (list 'defun '-operators- 'nil
  36.             (list 'quote
  37.                 (   (lambda ( npr ) (npr '(+ - * /) 3))
  38.                     (lambda ( l r )
  39.                         (if (< r 2)
  40.                             (mapcar 'list l)
  41.                             (apply 'append (mapcar '(lambda ( a ) (mapcar '(lambda ( b ) (cons a b)) (npr l (1- r)))) l))
  42.                         )
  43.                     )
  44.                 )
  45.             )
  46.         )
  47.     )
  48.     (-operators-)
  49. )
Example:
  1. _$ (LM:math24 2 3 4 5)
  2. (
  3.     (* (+ (- 3.0 2.0) 5.0) 4.0)
  4.     (* (+ (+ 3.0 4.0) 5.0) 2.0)
  5.     (* (- (+ 3.0 5.0) 2.0) 4.0)
  6.     (* (+ (+ 3.0 5.0) 4.0) 2.0)
  7.     (* (+ (+ 4.0 3.0) 5.0) 2.0)
  8.     (* (+ (+ 4.0 5.0) 3.0) 2.0)
  9.     (* (+ (- 5.0 2.0) 3.0) 4.0)
  10.     (* (- (+ 5.0 3.0) 2.0) 4.0)
  11.     (* (+ (+ 5.0 3.0) 4.0) 2.0)
  12.     (* (+ (+ 5.0 4.0) 3.0) 2.0)
  13. )
qjchen
« Reply #7 on: June 12, 2016, 08:38:33 AM »
Hi, Lee Mac, thank you very much for your participation. Sorry for my late reply, I just see your code after one day of tired working.
It is a great code, but I found that in some case it can not get a result.
Just like,  for (1 1 5 7) we can do it as (* (+ 1 1) (+ 5 7)) but your code get a nil result.
Furthermore,  just for some special case, just like (4 4 7 7) it can has such answer (* (- 4 (/ 4 7)) 7) and your code get a nil results too.  [Because in some 24 point games, no fraction result or expression is allowed, but I hope that it can be also allowed in this code]
Your code is very beautiful and I am sure it is easy for you to make it works under these two cases also.
Thanks again.
« Reply #8 on: June 12, 2016, 09:32:16 AM »
Thank you qjchen for your feedback, I appreciate your compliments for my code and thank you for pointing out its deficiencies.
The following should address your second point (though the code is becoming increasingly inefficient):
  2.     (-unique-
  3.         (vl-remove-if
  4.            '(lambda ( x / r )
  5.                 (or (vl-catch-all-error-p (setq r (vl-catch-all-apply 'eval (list x))))
  6.                     (not (equal 24.0 r 1e-8))
  7.                 )
  8.             )
  9.             (apply 'append
  10.                 (mapcar
  11.                    '(lambda ( a )
  12.                         (apply 'append
  13.                             (mapcar '(lambda ( b ) (-formulate- b (car a) (cdr a))) (-operators-))
  14.                         )
  15.                     )
  16.                     (   (lambda ( npr ) (-unique- (npr (mapcar 'float (list a b c d)) 4)))
  17.                         (lambda ( l r )
  18.                             (if (< r 2)
  19.                                 (mapcar 'list l)
  20.                                 (apply 'append (mapcar '(lambda ( a ) (mapcar '(lambda ( b ) (cons a b)) (npr (-remove1st- a l) (1- r)))) l))
  21.                             )
  22.                         )
  23.                     )
  24.                 )
  25.             )
  26.         )
  27.     )
  28. )
  29.
  30. (defun -formulate- ( o x l )
  31.     (if (and o l)
  32.         (if (member (car o) '(- /))
  33.             (append
  34.                 (-formulate- (cdr o) (list (car o) x (car l)) (cdr l))
  35.                 (-formulate- (cdr o) (list (car o) (car l) x) (cdr l))
  36.             )
  37.             (-formulate- (cdr o) (list (car o) x (car l)) (cdr l))
  38.         )
  39.         (list x)
  40.     )
  41. )
  42.
  43. (defun -remove1st- ( x l )
  44.     (cond
  45.         (   (not l) nil)
  46.         (   (equal x (car l)) (cdr l))
  47.         (   (cons (car l) (-remove1st- x (cdr l))))
  48.     )
  49. )
  50.
  51. (defun -unique- ( l )
  52.     (if l (cons (car l) (-unique- (vl-remove-if '(lambda ( x ) (equal x (car l))) (cdr l)))))
  53. )
  54.
  55. (defun -operators- nil
  56.     (eval
  57.         (list 'defun '-operators- 'nil
  58.             (list 'quote
  59.                 (   (lambda ( npr ) (npr '(+ - * /) 3))
  60.                     (lambda ( l r )
  61.                         (if (< r 2)
  62.                             (mapcar 'list l)
  63.                             (apply 'append (mapcar '(lambda ( a ) (mapcar '(lambda ( b ) (cons a b)) (npr l (1- r)))) l))
  64.                         )
  65.                     )
  66.                 )
  67.             )
  68.         )
  69.     )
  70.     (-operators-)
  71. )
« Reply #9 on: June 12, 2016, 09:49:18 AM »
The following should address the case of 1,1,5,7:
  2.     (-unique-
  3.         (vl-remove-if
  7.                 )
  8.             )
  9.             (apply 'append
  10.                 (mapcar
  11.                    '(lambda ( a )
  12.                         (apply 'append
  14.                         )
  15.                     )
  17.                         (lambda ( l r )
  18.                             (if (< r 2)
  21.                             )
  22.                         )
  23.                     )
  24.                 )
  25.             )
  26.         )
  27.     )
  28. )
  29.
  31.     (   (lambda ( foo ) (cons (list (car o) (list (cadr o) x (car l)) (list (caddr o) (cadr l) (caddr l))) (foo o x l)))
  32.         (lambda ( o x l )
  33.             (if (and o l)
  34.                 (if (member (car o) '(- /))
  35.                     (append
  36.                         (foo (cdr o) (list (car o) x (car l)) (cdr l))
  37.                         (foo (cdr o) (list (car o) (car l) x) (cdr l))
  38.                     )
  39.                     (foo (cdr o) (list (car o) x (car l)) (cdr l))
  40.                 )
  41.                 (list x)
  42.             )
  43.         )
  44.     )
  45. )
  46.
  47. (defun -remove1st- ( x l )
  48.     (cond
  49.         (   (not l) nil)
  50.         (   (equal x (car l)) (cdr l))
  51.         (   (cons (car l) (-remove1st- x (cdr l))))
  52.     )
  53. )
  54.
  55. (defun -unique- ( l )
  56.     (if l (cons (car l) (-unique- (vl-remove-if '(lambda ( x ) (equal x (car l))) (cdr l)))))
  57. )
  58.
  59. (defun -operators- nil
  60.     (eval
  61.         (list 'defun '-operators- 'nil
  62.             (list 'quote
  63.                 (   (lambda ( npr ) (npr '(+ - * /) 3))
  64.                     (lambda ( l r )
  65.                         (if (< r 2)
  66.                             (mapcar 'list l)
  67.                             (apply 'append (mapcar '(lambda ( a ) (mapcar '(lambda ( b ) (cons a b)) (npr l (1- r)))) l))
  68.                         )
  69.                     )
  70.                 )
  71.             )
  72.         )
  73.     )
  74.     (-operators-)
  75. )
qjchen
« Reply #10 on: June 12, 2016, 10:07:33 AM »
Thank you very much Lee Mac, your last code (#9) can solve all the question.  You are always a Lisp Master.
The following is my code now. But your code are much elegant than mine. I will also try my best to make some improvement. My code doesnt deal with the duplicate, I also need to improve.
I am also hoping other friend to take part in. :)
  1. (defun x&y (x y x1 y1)
  2.   (list (cons (cons '+ (list x1 y1)) (+ x y))(cons (cons '- (list x1 y1)) (- x y))(cons (cons '- (list y1 x1)) (- y x))
  3.         (cons (cons '* (list x1 y1)) (* x y))(cons (cons '/ (list x1 y1)) (if (eq y 0) 1e10 (/ x y) ) )(cons (cons '/ (list y1 x1)) (if (eq x 0) 1e10 (/ y x) ) )
  4.   )
  5. )
  6. (defun c:test (/ l1 l2  lst lst1 pub ress seq0 seq1 x x0 x2 xinl1 xinl2 xinseq1)
  7.   (setq lst  (list (getreal "\na:")(getreal "\nb:")(getreal "\nc:")(getreal "\nd:")) ress nil)
  8.   (setq seq0 (list (list '(0 1) 2 3) (list '(0 2) 1 3) (list '(0 3) 1 2) (list '(1 2) 0 3) (list '(1 3) 0 2) (list '(2 3) 0 1)))
  9.   (foreach x0 seq0
  10.    (setq l1 (x&y (nth (car (car x0)) lst) (nth (cadr (car x0)) lst) (nth (car (car x0)) lst) (nth (cadr (car x0)) lst) ) seq1 (list (list 1 2) (list 2 1)))
  11.    (foreach xinseq1 seq1
  12.       (foreach xinl1 l1
  13.         (setq lst1 (x&y (cdr xinl1) (nth (nth (car xinseq1) x0) lst) (car xinl1) (nth (nth (car xinseq1) x0) lst)))
  14.         (foreach x2 lst1
  15.          (setq pub (x&y (cdr x2) (nth (nth (cadr xinseq1) x0) lst) (car x2) (nth (nth (cadr xinseq1) x0) lst)) ress (append ress pub))
  16.         )
  17.       )
  18.    )
  19.    (setq l2 (x&y (nth (cadr x0) lst) (nth (caddr x0) lst) (nth (cadr x0) lst) (nth (caddr x0) lst)))
  20.    (foreach xinl1 l1
  21.     (foreach xinl2 l2
  22.       (setq pub (x&y (cdr xinl1) (cdr xinl2) (car xinl1) (car xinl2)) ress (append ress pub))
  23.     )
  24.    )
  25.   )
  26.   (foreach x ress
  27.     (if (eq (cdr x) 24.0) (progn (princ x) (princ "\n")))
  28.   )
  29. )
  30.
« Last Edit: June 12, 2016, 10:11:00 AM by qjchen »
squirreldip
« Reply #11 on: June 13, 2016, 06:55:33 PM »
Here's another using and evaluating strings:
(defun RFL:MATH24 (NUMLIST / A B C D FCTN FCTN1 FCTN2 FCTN3 FCTN4 RES STR)
 (defun FCTN (STR) (eval (read STR)))
 (foreach A '(0 1 2 3)
  (foreach B '(0 1 2 3)
   (if (/= A B)
    (foreach C '(0 1 2 3)
     (if (and (/= C B) (/= C A))
      (foreach D '(0 1 2 3)
       (if (and (/= D C) (/= D B) (/= D A))
        (foreach FCTN3 (list "+" "-" "*" "/")
         (foreach FCTN2 (list "+" "-" "*" "/")
          (foreach FCTN1 (list "+" "-" "*" "/")
           (setq STR (strcat "(" FCTN1 " " (rtos (nth A NUMLIST)) " (" FCTN2 " " (rtos (nth B NUMLIST)) " (" FCTN3 " " (rtos (nth C NUMLIST)) " " (rtos (nth D NUMLIST)) ")))"))
           (setq RES (vl-catch-all-apply 'FCTN (list STR)))
           (if (and (not (vl-catch-all-error-p RES)) (= RES 24)) (print STR))
 (print "Done!")
(rfl:math24 (list 2 3 4 5))
"(* 2.0 (+ 3.0 (+ 4.0 5.0)))"
"(* 2.0 (+ 3.0 (+ 5.0 4.0)))"
"(* 2.0 (+ 4.0 (+ 3.0 5.0)))"
"(* 2.0 (+ 4.0 (+ 5.0 3.0)))"
"(* 2.0 (+ 5.0 (+ 3.0 4.0)))"
"(* 2.0 (+ 5.0 (+ 4.0 3.0)))"
"(* 4.0 (- 3.0 (- 2.0 5.0)))"
"(* 4.0 (+ 3.0 (- 5.0 2.0)))"
"(* 4.0 (- 5.0 (- 2.0 3.0)))"
"(* 4.0 (+ 5.0 (- 3.0 2.0)))"
"Done!"
qjchen
« Reply #12 on: June 13, 2016, 08:08:35 PM »
Thank you squirreldip!
It is a very good way to get the result of  this type of solution: "(* 2.0 (+ 3.0 (+ 4.0 5.0)))"
However, for some case, just like  (1, 1, 5, 5), it can also be solved by
(* (+ 1.0 5.0) (- 5.0 1.0))    or
(- (* (* 1.0 5.0) 5.0) 1.0)
but your code show nil result.
Could you please add some codes to make all of them also be solved?
Thank you very much.
