Author Topic: ToolPalettes: Where are stored the user-defined images?  (Read 1289 times)
Peter2
« on: June 10, 2016, 05:04:27 PM »
I made a new toolpalette with some commands to draw "lines" and to write "dtext", modified text and description, used the original icons (images) and saved to XPG file (exported).
Then I defined 10 different BMP (32x32) to the 10 commands, and they are displayed well. Then I exported again - and the new XPG is the same one as the previous one.
Question:
How are the user-defined images handled?
Where and how are they referenced?
Are they stored internally (like MNR)?
Thanks and have a fine weekend
Peter
BricsCAD V23
Peter2
Re: ToolPalettes: Where are stored the user-defined images?
« Reply #1 on: June 10, 2016, 05:21:01 PM »
Solved:
Images are moved to
C:\Users\myname\AppData\Roaming\Autodesk\AutoCAD 2014\R19.1\deu\Support\ToolPalette\Palettes\Images
other info is stored in ATC-Files in
« Last Edit: June 10, 2016, 05:26:59 PM by Peter2 »
Peter
BricsCAD V23
