Author Topic: Toolbutton Command Transparency  (Read 1629 times)
novice
« on: May 24, 2016, 02:11:44 PM »
I've just started editing the CUI for the first time. Made a custom toolbar. Added a few AutoCAD commands to it. Added a couple of my lisp routines. Tried my hand at a pull-down menu, too. Added a lisp routine to it. So far so good.
But now I want to make a toolbutton for a lisp routine that I always use transparently. But when I click the new toolbutton with this command, it always takes me out of the original command and then starts my new command. So it doesn't work transparently.
In the CUI, I defined the macro with the apostrophe for the transparency: my lisp routine is CC, I always use it transparently on the command line by typing 'CC in the middle of a command, and the macro in the CUI looks like this: ^C^C_'cc
Any suggestions? I can't find anything on Google...
dgorsman
Re: Toolbutton Command Transparency
« Reply #1 on: May 24, 2016, 02:39:28 PM »
You do know what that "^C^C" prefix does, right?   ;-)
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Rob...
« Reply #2 on: May 24, 2016, 02:41:10 PM »
I was thinking that, also.
CAD Tech
ChrisCarlson
« Reply #3 on: May 24, 2016, 02:45:47 PM »
http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-D991386C-FBAA-4094-9FCB-AADD98ACD3EF
^C^C
Special control character sequence
Sequence that is similar to pressing the Esc key twice.
novice
« Reply #4 on: May 24, 2016, 03:09:51 PM »
Lol, thanks everyone. Solved.
