I write an Installing Wizard for my plugin (through WiX Tools). It is to be installed into one of the predefined folders:
- %ProgramFiles%\Autodesk\ApplicationPlugins\<MyPluginName>.bundle\
- %AppData%\Autodesk\ApplicationPlugins\<MyPluginName>.bundle\
- %ProgramData%\Autodesk\ApplicationPlugins\<MyPluginName>.bundle\
I want to provide the target directory in the Installing Wizard through the
RadioButtonGroup (with that three variants) for user could select the variant which is necessary to him (instead of using the
WixUI_InstallDir interface with button for manually changin the target directory).
How can I do it?
