Author Topic: Custom Flow Arrows?  (Read 8221 times)
BlackBox
Custom Flow Arrows?
« on: May 23, 2016, 06:22:15 PM »
What's the trick to making a custom Flow Arrow from a Block?
I'm attempting to label a Surface via Two Point Slope label. The Block shows fine, but does not adjust to the actual flow direction on its own, when anchored to the feature. I've tried adding a Directional Arrow and anchoring to that instead, but no change.
My Line/Curve and Pipe flow arrows work fine also, but they use an Arrow, not a Block component.
Cheers
Jeff_M
  • C3D user & customizer
Re: Custom Flow Arrows?
« Reply #1 on: May 23, 2016, 06:57:36 PM »
Attaching to the Direction arrow works for me. Can you attach a drawing or screencast?
MSTG007
« Reply #2 on: May 24, 2016, 07:14:39 AM »
Hmm... I don't think we ever tried to do that. I know we use a lot of the One Point Directional Slope Arrow Labels, but again those do not have custom blocks in them. I would be cool to see if you get this to work.
Civil3D 2020
BlackBox
« Reply #3 on: May 24, 2016, 09:33:14 AM »
Okay -
I tried this again this morning, and am getting the same result; which is to say that the Block component 'follows' the Direction Arrow component in a two point slope label, but neither depict the actual slope (down, from HP to LP). They both instead 'flow' toward the first point in the two point slope label.
Do I have to create an Expression to get it to always 'flow' down grade, like water actually does out here in the real-world? :?
I don't actually want the Directional Arrow to show; I just let it be displayed using all default settings for clarity in the images below.
Jeff_M
« Reply #4 on: May 24, 2016, 09:36:55 AM »
I'm attaching a tutorial drawing with a mock slope style. It has the direction arrow still displayed, as well as having a block component. It uses an expression so the arrow, and block, always point downhill.
MSTG007
« Reply #5 on: May 24, 2016, 09:45:41 AM »
Very Cool. I see the expression is simple. I don't know why it would not work OOTB.
Civil3D 2020
« Reply #6 on: May 24, 2016, 09:48:06 AM »
Civil 3D, if it is not driving you crazy; you aren't using it right.
BlackBox
« Reply #7 on: May 24, 2016, 10:59:00 AM »
... It uses an expression [that is not included with Civil 3D] so the arrow, and block, always point downhill.
This Expression is exactly what I was after, Jeff - thank you! :-)
Now I don't even need the Directional Arrow; just assign the Expression to the Block's rotation angle, and done! :wink:
Code - Text: [Select]
  1. IF({Surface Slope}<=0,0,pi)
Jeff_M
« Reply #8 on: May 24, 2016, 11:50:17 AM »
Well, C3D does not ship with ANY Expressions, so this shouldn't be a big surprise.
Jeff_M
« Reply #9 on: May 24, 2016, 11:53:32 AM »
I should also note that I found the slope rotation expression on a post at the old Civil3D.com website run by James Wedding and Dana Probert, c. 2007. I think it may have been a post by Matt Kolberg....ah, my memory sure ain't what it used to be.
« Reply #10 on: May 24, 2016, 12:25:54 PM »
Nor do they explain exactly how to form, and or use an Expression, anywhere in official documentation.
MSTG007
« Reply #11 on: May 24, 2016, 01:20:01 PM »
Does Dana P. work for Autodesk now?
Civil3D 2020
Jeff_M
« Reply #12 on: May 24, 2016, 01:22:09 PM »
Yes, she does. I believe she is what they have termed a "product evangelist".
Jeff_M
« Reply #13 on: May 24, 2016, 01:25:00 PM »
« Reply #14 on: May 24, 2016, 02:12:14 PM »
Really?
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-27126EB8-AE17-4119-A898-35158B1BBDA-2766.htm#GUID-6B8321E9-313F-4649-80FA-3EAF829076C0
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-0B593837-EF95-4E34-8689-CB48F8ADF94-2150.htm
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-F767C568-5609-4163-8DC7-CC266344E05-2151.htm
Well, that was for C3D2012, as that is what I have open at the moment, but I'm pretty sure the newer versions contain these pages as well.
Ok let me rephrase that, no good usable / practical examples....
when was the last time I needed to "Converting Astronomic Direction to Magnetic Direction" ?  Exactly Never
BlackBox
« Reply #15 on: May 24, 2016, 04:55:22 PM »
It shouldn't... but it is though... but it shouldn't. Haha
My only point in that, is that a Surface Slope Label's Directional Arrow *should* ultimately 'slope' either up, or down OOTB... A directional arrow that just points in the direction it is drawn, is just an arrow (Leader?).  :-D
I'm not asking for an Expression for each potentiality of all customers, however, some 'useful' examples, even if opposite what I may want to use, would be helpful, IMHO.  That's all. :-)
« Reply #16 on: May 24, 2016, 05:17:20 PM »
yes...USEFUL examples would be nice to have
sljohnson
« Reply #17 on: May 25, 2016, 12:12:04 PM »
Hello BlackBox,
We have a custom slope arrow as well, however ours works as expected with no expressions. Would it be possible to share the original non expression style?
I remember ours not initially working. I don't remember what I did to fix it, however I'd like to get in the weeds and see whats different between yours and ours.
