Author Topic: merge list_layer to another list_layer  (Read 4073 times)
new_mem
« on: May 22, 2016, 10:10:30 AM »
Hi all
I have lst_lay1 (list "1" "2" "3" "4" "5" "6" "n") and lst_lay2 (list "1new" "2new" "3new" "4new" "5new" "6new" "n_new")
How can i merge list layer1 to list layer2 (1->1new, 2->2new,....)
Can anyone tell me, please?
Re: merge list_layer to another list_layer
« Reply #1 on: May 22, 2016, 10:18:36 AM »
If I understand you, you can use 'mapcar' on the two list to create a single new one from both members.  An issue with length might happen if they are not the same length.
You could use a 'repeat' loop grabbing the indexed values of each list, and them combining them.  Just start a counter variable outside the loop, and then...
That is it for now.
« Reply #2 on: May 22, 2016, 10:21:50 AM »
What are you ultimately trying to achieve? Seems the second list is derivative the first, so constructing it manually serves no value other than to introduce potential errors.
PS: On first coffee, so take that for what it's worth.
new_mem
« Reply #3 on: May 22, 2016, 10:25:17 AM »
thanks for repply,
here my code/
(defun c:123 (/ lst1 lst2 e new_name)
  (setq lst1 (list "1" "2" "3" "4" "5" "6"))
  (setq lst2 (list "1new" "2new" "3new" "4new" "5new" "6new"))
  (command "_.LAYMRG")
  (foreach e lst1
    (if (tblsearch "LAYER" e)
   (setq new_name (car lst))
   (command "_Name" e "" "_N" new_name "_Y")
   (setq lst (cdr lst))
   );progn
      );if
    );foreach
Long time i dont use mapcar. Pls tell me, thanks.
« Reply #4 on: May 22, 2016, 10:30:07 AM »
So you are trying to rename a layer if the layer is found, based on two lists?
Code - Lisp: [Select]
  1. (foreach i (mapcar (function cons) list1 list2)
  2.     (if .... search of '(car i)'
  3.         ... rename '(car i)' to '(cdr i)'..
  4.     )
  5. )
  6.
Typed in message, so be careful, but the idea is there.[/code]
« Reply #5 on: May 22, 2016, 10:33:29 AM »
Or even ....
I am so glad I learned 'mapcar' within Lisp.  I am using 'map' within Python code, and it seems no-one else is.  What a waste.
  1. (mapcar (function (lambda (a b) (if ... layer a is found .... change layer a name to b ) ) ) list1 list2 )
  2.
« Reply #6 on: May 22, 2016, 10:36:58 AM »
What my caffeine deprived brain thinks ...
    (vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
        (if (wcmatch (strcase (setq name (vla-get-name layer))) "~*NEW")
            (vl-catch-all-apply 'vla-put-name
                (list layer (strcat name "new"))
Subtitle: Mapcar is a great function but not the solution for everything.
« Reply #7 on: May 22, 2016, 10:44:27 AM »
MP,
I thought one should not change the contents of the a collection when stepping through the collection?  I would make a list of the items to change, and then change them after stepping through the collection.  Maybe I am remembering wrong about that though.
True, but it can be a great tool for applying a function to a whole list of items.
« Reply #8 on: May 22, 2016, 11:05:29 AM »
Hi Tim, if one intends to add or delete items from a collection then it would be ill advised to do so while iterating it. In the code snip I provided I'm merely abusing a collection item's property (name) that has no impact upon the container (aside from potential duplicate key or non modifiable layer, ergo the catch code).
For example, if I were iterating thru the dictionary collection looking to delete any dictionary entry with an "AEC" prefix I'd collect the offending dictionaries in a temporary list and then delete all the items in said temporary list.
new_mem
« Reply #9 on: May 22, 2016, 11:15:08 AM »
  4.     )
  5. )
  6.
i dont want rename layer because if layer 1new have in drawing. i mean creat lst layer new then merge layer_old with new. I have not found the answer loop.
(defun c:123 (/ lst1 lst2 n layer1 layer2)
  (setq n 0)
  (repeat
    (SsLength lst1)
    (setq layer1 (nth n lst1))
    (setq layer2 (nth n lst2))
    (if (tblsearch "LAYER" layer1)
      (if (tblsearch "LAYER" layer2)
   (command "_.LAYMRG" "_Name" layer1 "" "_N" layer2 "_Y")
   );if layer2
      );if layer1
    (setq n (+ n 1))
Pls check it.
new_mem
« Reply #10 on: May 22, 2016, 11:17:57 AM »
thanks for repply.
But i mean any layer : 1->abc , 2->dahfds, 3->........
new_mem
« Reply #11 on: May 22, 2016, 11:45:02 AM »
  4.     )
  5. )
  6.
  (setq n 0)
  (repeat
    (SsLength lst1)
   );if layer2
      );if layer1
    (setq n (+ n 1))
Pls check it.
wrong sslength. i have change length.
It work.
Thank you.
« Reply #12 on: May 22, 2016, 12:00:49 PM »
If I've correctly understood:
  1. (defun renamelayers ( lst / new )
  2.         (if (setq new (cdr (assoc (vla-get-name lay) lst)))
  3.             (vl-catch-all-apply 'vla-put-name (list lay new))
  4.         )
  5.     )
  6. )
  1. (renamelayers (mapcar 'cons lst1 lst2))
new_mem
« Reply #13 on: May 22, 2016, 12:09:53 PM »
  4.         )
  5.     )
  6. )
Thanks for your funtion mapcar
I mean:
1. Creat my layer by import layer_iso (color, linetype, Linewight...)
2. Merge layer current drawing to layer_iso
My project is following ATKIN design. And my boss want to change layer ATK to my office iso.
Thanks again.
LeeMac
How can i merge layer multi drawing in folder but dont open drawing. I saw bfind lisp magic.  :smitten:
« Last Edit: May 22, 2016, 12:46:11 PM by new_mem »
« Reply #14 on: May 22, 2016, 12:24:55 PM »
Thanks, MP.  That seems more right than what I was thinking.
Glad to hear you got something working for yourself, new_mem.
