Author Topic: Remove from Multiple attributes at once?  (Read 2528 times)
craigr
« on: May 18, 2016, 11:57:27 AM »
See the attached CAD file.
All I need is the Room Name & Number.  I want to remove the '#### SF' from every instance, without having to edit every one.
I looked at the ‘edit attribute’ option, but I don’t see anything in there that would delete this line.
IS there a way to do this to ALL of them at once?
cadtag
Re: Remove from Multiple attributes at once?
« Reply #1 on: May 18, 2016, 12:18:17 PM »
Find works in 2014 (full)  just use "??? SF" for the string to search on, and an empty space as the replacement.
130 odd instances replaced in milliseconds
The only thing more dangerous to the liberty of a free people than big government is big business
« Reply #2 on: May 18, 2016, 12:18:48 PM »
Like so?  :)
Rob...
« Reply #3 on: May 18, 2016, 12:20:09 PM »
Edit the block.
Erase the attribute.
Save the block.
ATTSYNC
CAD Tech
« Reply #4 on: May 18, 2016, 12:21:45 PM »
Find works in 2014 (full)  just use " :? SF" for the string to search on, and an empty space as the replacement.
To expand on this you have to make sure the wildcard option is checked.
Jeff H
« Reply #5 on: May 18, 2016, 12:21:57 PM »
can't you just edit block, delete attribute then ATTSYNC on block?
*********edit********
DOH!
Rob already posted
Edit the block.
Save the block.
ATTSYNC
« Reply #6 on: May 18, 2016, 12:24:39 PM »
That was my first thought too but look at how some of the blocks are filled out:
Rob...
« Reply #7 on: May 18, 2016, 12:54:11 PM »
It does work but the problem is that there is at least four different blocks at use for the same thing. Some of the square footages are plain text to complicate matters even more. Find and replace is the fastest solution but my OCD would make me edit the blocks and delete the text entities.
CAD Tech
craigr
« Reply #8 on: May 18, 2016, 02:04:16 PM »
One thing I initially tried was to create 'Junk' Layer and thru the Attribute editor, set the SF line to that 'Junk' layer. I then turn that layer off and set it to 'no print'.
But, my OCD won't let me cheat like that.  (though it does work)
« Reply #9 on: May 18, 2016, 02:17:21 PM »
That seems like much more work than find & replace.
« Reply #10 on: May 18, 2016, 02:23:02 PM »
Actually after testing, the find & replace it does not do what you want. It leaves the number & only removes the SF.
*EDIT: Using filter '#*SF' works.
« Last Edit: May 18, 2016, 02:28:30 PM by ronjonp »
Bryco
« Reply #11 on: May 21, 2016, 03:35:59 PM »
Isolate "Roomnumbers layer"->select all ->Quick select->block reference->name->operator=wildcard match->value=BP*->in properties window UNDER ATTRIBUTES,NUMBER delete "varies",
this gets all the blocks sorted. Can do the same for text
